Compression testing (I need advice) repost
I was doing compression test on my b18c1 engine w/ 10k miles and I got the following numbers:
1 2 3 4
210psi 200 200 220----I got 220 after the third attempt, the first two times I got 135psi and when I put a teaspoon of oil in the cylinder I got 220 and then 235psi ----IS THIS NORMAL? Please reply. Thanks (I was not pressing the gas...)
1 2 3 4
try keeping the throttle fully open next time.. and how many times did you crank the engine? You also might wanna disable your fuel injectors by either pulling the wire harnesses by the distributor or pulling the ecu fuse if you haven't done that already. 135 seems kinda low...
try going to http://www.c-speedracing.com they have an awesome how to section. They have a how to do a compression test with full description...hope that helps
I think u have to hold the gas,if I remember coerrectly...check the site
