Fender rolling?
Old Sep 4, 2003 | 12:53 PM
Steve90HB's Avatar
Default Fender rolling?
This sucks, I just installed my camber kit - but the alignment place can't do a correction because my fender would be rubbing... anyone have a walk through on how to do the bat trick or whatever it's called? (I searched and found some topics, but none explained how to do the bat trick)
Need to get this done ASAP, don't want to put on a set of new tires and have them wear too!!!
Old Sep 4, 2003 | 01:00 PM
DubbleD's Avatar
Default Re: Fender rolling? (Steve90HB)
did you try searching eg/civic i think they have discussed that more than a few times..
Old Sep 4, 2003 | 01:26 PM
travis's Avatar
Default Re: Fender rolling? (DubbleD)
There's a good how-to out there. I'll see if I can find it. The bat technique is pretty simple. With the wheel/tire on, jack the car and insert bat. Jack the car down to wedge the bat between the fender and the car, then roll the bat the length of the fender (allowing the tire to turn as well). Depending on how much room you have, this may require jacking the car all the way down to the ground and rolling the whole car forward and backward.
Old Sep 4, 2003 | 01:38 PM
Steve90HB's Avatar
Default Re: Fender rolling? (travis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by travis &raquo;</TD></TR><TR><TD CLASS="quote">There's a good how-to out there. I'll see if I can find it. The bat technique is pretty simple. With the wheel/tire on, jack the car and insert bat. Jack the car down to wedge the bat between the fender and the car, then roll the bat the length of the fender (allowing the tire to turn as well). Depending on how much room you have, this may require jacking the car all the way down to the ground and rolling the whole car forward and backward.</TD></TR></TABLE>
that's seriously not making any sense to me...
from what I understand, I jack up a car enough to fit a bat under there, then I gradually lower it? I don't understand at all
Old Sep 4, 2003 | 02:01 PM
travis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Steve90HB &raquo;</TD></TR><TR><TD CLASS="quote">
LOL! Sorry...
Found it:
http://www.vtec.net/articles/v...=3511
Old Sep 4, 2003 | 02:30 PM
Steve90HB's Avatar
perfect, I had a different image in my mind
thanks
Old Sep 4, 2003 | 10:14 PM
PFRMotoCRX's Avatar
works wicked, not very nice to the paint........or to a wood bat
AJ
talkJDM
Suspension & Brakes
13
Jul 25, 2011 06:20 AM
De_tour
Suspension & Brakes
Dec 12, 2005 02:54 PM
HUBB
20
Jul 23, 2003 09:10 PM
sjteg
Jul 22, 2003 10:09 PM
tylerdurden
11
Dec 7, 2002 12:28 PM
