Limited Slip Questions...
Old Sep 4, 2003 | 12:47 PM
DJ Nokturnal's Avatar
Default Limited Slip Questions...
I tried the search and it came up with no results for my specific question (and I searched properly I hope ).
I am in the process of purchasing a B18C1 which apparently has LSD. My question is, is there a way to tell this is actually a LSD before I install it with a visual check?
Thanks guys
Andrew
HT Rules
Old Sep 4, 2003 | 12:50 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: Limited Slip Questions... (DJ Nokturnal)
Look through the differential hole where the axles stick into the tranny.
If you can look all the way through with nothing blocking your view, it HAS LSD.
If when you look through you see a pin or a "bar" sticking diagonally through the hole, then it is NOT an LSD.
Old Sep 4, 2003 | 12:53 PM
Spade's Avatar
Default Re: Limited Slip Questions... (B18C5-EH2)
Images courtsey of Katman
LSD
Non LSD
Old Sep 4, 2003 | 12:56 PM
Default Re: Limited Slip Questions... (Spade)
awesome... thanks for the awesome replies...
last rookie statement....
at which step of the install are these pics taken.... are these taken while the engine is attached to the tranny and the axels are just not installed?
am i close?
hehehe
Old Sep 4, 2003 | 12:59 PM
B18C5-EH2's Avatar
Former Moderator
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJ Nokturnal &raquo;</TD></TR><TR><TD CLASS="quote">awesome... thanks for the awesome replies...
am i close?
hehehe</TD></TR></TABLE>
You'll see the diff pin (or hopefully not) when the tranny is on or off the engine.
The only way you won't see it is if there are axles or inner joints attached in there.
Old Sep 4, 2003 | 01:00 PM
Archidictus's Avatar
Unceasing Measure
am i close?
Wow, a noobie with promise . Stick around for a while, you seem like good people .
Old Sep 4, 2003 | 01:02 PM
Spade's Avatar
Default Re: Limited Slip Questions... (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">
Wow, a noobie with promise . Stick around for a while, you seem like good people .</TD></TR></TABLE>
Seems like a good person. Damn Ohio redneck.
Old Sep 4, 2003 | 01:09 PM
awh you're making me blush
i soon hope to contribute instead of asking moronic rookie questions...
Old Sep 4, 2003 | 01:14 PM
EVIL Hx Coupe's Avatar
You searched before asking the question... When you asked you use punctuation and proper english... to rookies like you...
Old Sep 4, 2003 | 01:16 PM
Motts's Avatar
I have a noob question while on the subject. I was wondering what kind of LSD comes on the stock S80 ITR trans? I thought there were different kinds and I was curious which one this trans has.
Old Sep 5, 2003 | 10:12 AM
Spade's Avatar
Default Re: (Motts)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Motts &raquo;</TD></TR><TR><TD CLASS="quote">I have a noob question while on the subject. I was wondering what kind of LSD comes on the stock S80 ITR trans? I thought there were different kinds and I was curious which one this trans has.</TD></TR></TABLE>
I believe a helicial type.
Old Sep 5, 2003 | 10:30 AM
Skyllz's Avatar
Default Re: (Spade)
It should look something like this...
Just finished changing synchros in my R tranny
Old Sep 5, 2003 | 10:40 AM
Spade's Avatar
Default Re: (Skyllz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skyllz &raquo;</TD></TR><TR><TD CLASS="quote">It should look something like this...
Just finished changing synchros in my R tranny </TD></TR></TABLE>
To me, that is sexy.
Old Sep 5, 2003 | 10:44 AM
acuracing's Avatar
Default Re: (Spade)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spade &raquo;</TD></TR><TR><TD CLASS="quote">
To me, that is sexy.</TD></TR></TABLE>
So I'm not the only one that thinks that...
Old Sep 5, 2003 | 10:51 AM
Spade's Avatar
Default Re: (acuracing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acuracing &raquo;</TD></TR><TR><TD CLASS="quote">
So I'm not the only one that thinks that...</TD></TR></TABLE>
Old Sep 5, 2003 | 11:01 AM
Skyllz's Avatar
I have to admint it does look ALOT harder then it was.
Only time consuming and having to reassemble the main shaft 5 times due to not putting everything back like it was supposed to be. otherwise all ok!!!
Old Sep 5, 2003 | 01:06 PM
RyanEJ8's Avatar
No you're not.
Old Sep 5, 2003 | 01:15 PM
Ricey McRicerton's Avatar
Default Re: (Spade)
You and me both!
Old Sep 5, 2003 | 01:21 PM
Marauder's Avatar
Default Re: (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">
You and me both!</TD></TR></TABLE>
You guys need to get out of the garage more! Those oil, coolant, fuel, and tranny fluid fumes are clouding your juedgement!
Old Sep 5, 2003 | 01:23 PM
tek_civic's Avatar
cool, where did you buy the syncros from? how much was the whole rebuild? like gaskets, misc seals, clips, syncro rings, all that good stuff.
Old Sep 5, 2003 | 01:41 PM
Spade's Avatar
Default Re: (Marauder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marauder &raquo;</TD></TR><TR><TD CLASS="quote">
You guys need to get out of the garage more! Those oil, coolant, fuel, and tranny fluid fumes are clouding your juedgement! </TD></TR></TABLE>
LoL....just cause we do our own work, unlike someone I won't meantion.
J/P
Old Sep 5, 2003 | 02:15 PM
Skyllz's Avatar
Default Re: (tek_civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tek_civic &raquo;</TD></TR><TR><TD CLASS="quote">cool, where did you buy the syncros from? how much was the whole rebuild? like gaskets, misc seals, clips, syncro rings, all that good stuff.</TD></TR></TABLE>
well... 800$ Can. later...
Synchros for 1-2 3-4
A tube of Permatex Ultra-Grey
2 litres of Honda MTF
Thats all folks. Synchros are a bitch to buy here, next time i'll order them threw the US, even with exchange and duties and taxes, it'll be cheaper.
It's only time consuming. That's all.
Old Sep 5, 2003 | 02:17 PM
Skyllz's Avatar
Default Re: (Spade)
You have not seem my GF working on her car or her KAwasaki 636 yet... *drooling*
And no you guys wont have pics
98oRange
Apr 8, 2005 06:45 PM
playAho
20
Sep 13, 2003 05:59 AM
CRX A4
Apr 5, 2003 04:04 AM
hybridhatch90
Sep 22, 2002 12:19 PM
d mafia
Jan 18, 2002 09:52 PM
