any one know anything about srs?
Well my car has had the SRS light on, cruise control not working, and horn not working since I've had it( about a year). So after some searching here on honda-tech I decided all I had to do was buy a cable reel for it and I should solve the problem. I got a cable reel from some one on here and put it on today, so then I tried checking the SRS code (which I should have done in the first place ) and it just stays solid, when I turn on the car it just stays solid, and when I tried to erase the memory on the jumper next to the fuse box (acording to the helm manual) and, it stayed solid.
Recap: why does my SRS light stay on no matter what I do?
Any suggestions.?
~Thanks
Any suggestions.?
~Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by theman-dlh »</TD></TR><TR><TD CLASS="quote">Well my car has had the SRS light on, cruise control not working, and horn not working since I've had it( about a year). So after some searching here on honda-tech I decided all I had to do was buy a cable reel for it and I should solve the problem. I got a cable reel from some one on here and put it on today, so then I tried checking the SRS code (which I should have done in the first place ) and it just stays solid, when I turn on the car it just stays solid, and when I tried to erase the memory on the jumper next to the fuse box (acording to the helm manual) and, it stayed solid.
Any suggestions.?
~Thanks
you bought it with the light on? hmm.. could be a problem within the SRS system, like the airbags or the control module or something..
if not, then i'm not really sure what to tell you.. The helms just said to erase the jumper memory? What vehicle is this, anyhow?
n/m, teg.. saw your sig..
Any suggestions.?
~Thanks
first I tried to check the trouble code, and the light stayed on- no blinks.
So I thought I would erase the code to see if it would come back.
but that didn't work. I'm thinking it is just something wrong with my SRS ecu.
Thanks for the input guys
ebrake? what is that supposed to mean?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by theman-dlh »</TD></TR><TR><TD CLASS="quote">first I tried to check the trouble code, and the light stayed on- no blinks.
ebrake? what is that supposed to mean?</TD></TR></TABLE>
yeah.. could definitely be the control module.. or a sensor.. that's weird to not draw a code either way though..
ignore the ebrake thing, that's not it.. ebrake problems would make the BRAKE light come on..
i would assume you have to at least reset it somehow, but i'm not sure..
to be quite honest, you should cross post a link to this in the integra or ITR forum.. you might get some more knowledgeable answers..
blkgsr03
Jan 15, 2006 10:36 PM
Mackd007
17
May 19, 2005 08:20 PM
