JRSC for Type R and SIR... Are they the same???
Old Sep 4, 2003 | 08:54 AM
R6Boy69's Avatar
Default JRSC for Type R and SIR... Are they the same???
theres a little debate goin on over at clubSi.com, and i just wanna prove someone wrong... are the blowers for the Sir and type R the same? I know that they can both be interchanged but someone seems to think that the blower for the Type R is larger than the SIR. I did a search and couldn't find anything.
Old Sep 4, 2003 | 09:04 AM
Spunkster's Avatar
Default Re: JRSC for Type R and SIR... Are they the same??? (crXBoy69)
THey both use the M62 Eaton roots blower. I know that the ITR uses a nose pully from JAckson with a diameter of 4.2 inches. I'm not sure of the diameter on the SI/SIR (silly canadians).
Old Sep 4, 2003 | 09:43 AM
SiRkid's Avatar
Default Re: JRSC for Type R and SIR... Are they the same??? (Spunkster)
they are same
Old Sep 4, 2003 | 10:02 AM
metal-x's Avatar
Default Re: JRSC for Type R and SIR... Are they the same??? (SiRkid)
Isn't the M62 for a B18C and M45 for SIR/ITR ?
Old Sep 4, 2003 | 01:20 PM
roadrunner's Avatar
Default Re: JRSC for Type R and SIR... Are they the same??? (metal-x)
From what I've seen, all VTEC B series kits use the M62. The only differences I would imagine would be in the alternator/tensioning bracket that bolts to the head and the block. It might be taller for the B18 kits due to the longer stroke.
Old Sep 4, 2003 | 03:36 PM
CRVRX's Avatar
Default Re: JRSC for Type R and SIR... Are they the same??? (roadrunner)
The Type R and the B16A kits are the same, both use the same pulley size ( 4.2") and the same blower ( M62). If you purchase the kit new , the type R kit comes with a new fuel pump.
The GSR kits uses the same blower ( M62) , the pulley size is 4.0" and all kits use the same bracket assembly.
The LS and B20 kit uses the same bracket assembly , but the M45 Blower and differant manifolds.
Hope this clears it up.
Old Sep 4, 2003 | 03:58 PM
SiRkid's Avatar
Default Re: JRSC for Type R and SIR... Are they the same??? (CRVRX)
the d series also use the m45.
I was right(on clubsi) and those guys are full of it
Old Sep 4, 2003 | 08:25 PM
R6Boy69's Avatar
lol hell yeah
Old Sep 7, 2003 | 10:54 AM
TOFU.man's Avatar
Yes they are the same.
SHUTTLE
Dec 23, 2008 11:13 AM
Bmaga123
Sep 22, 2005 08:02 AM
puffidredz
Jun 26, 2005 02:47 PM
motore
Aug 27, 2003 09:02 PM
motore
Aug 27, 2003 09:00 PM
