Launching close to 400whp on street tires?
Old Sep 4, 2003 | 08:42 AM
01ITR#700's Avatar
Default Launching close to 400whp on street tires?
I know some guys are getting some good times with high HP and street tires these days. I was basically looking for any tips and/or tricks. I have no launch control device ie. 2-step etc. I'm broke and have zero funds for slicks this year after building the motor...
The car is an '01 ITR Turbo, roughly 400whp, running on stock 15" wheels and Falken Azenis 205-50-R15. I basically just got the new motor broken in and tried 1 or 2 soft launches on the street(back country road) and could not get traction in 1st or 2nd even at partial throttle.
Thanks for any info.
Mark
Old Sep 4, 2003 | 09:08 AM
autoEXturbo's Avatar
Default Re: Launching close to 400whp on street tires? (01ITR#700)
my only piece of advice is pat the gas. I launch at like 5k on my 195-55-15 kumho 711's and pulled a 12.7@122 spinning from launch thru the traps.
Old Sep 4, 2003 | 10:46 AM
MotorMatrix.com's Avatar
I am a bad person
Default Re: Launching close to 400whp on street tires? (autoEXturbo)
best advice is to get rid of the azenis. they dont hook period. get big bfg's and youll go 12's easy on 400whp.
Old Sep 4, 2003 | 01:32 PM
FULLTHROTTLE's Avatar
Default Re: Launching close to 400whp on street tires? (MotorMatrix.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MotorMatrix.com &raquo;</TD></TR><TR><TD CLASS="quote">best advice is to get rid of the azenis. they dont hook period. get big bfg's and youll go 12's easy on 400whp.</TD></TR></TABLE>
Werd. I love the sticky BFGs. Also love how good those broken axles look in my junk bin. Its not the tires fault though, just me being an animal at the start line.
Old Sep 4, 2003 | 10:32 PM
T4eg's Avatar
Default Re: Launching close to 400whp on street tires? (FULLTHROTTLE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FULLTHROTTLE &raquo;</TD></TR><TR><TD CLASS="quote">
Werd. I love the sticky BFGs. </TD></TR></TABLE>
awesome street tire
Old Sep 4, 2003 | 11:25 PM
Boost2NA's Avatar
Default Re: Launching close to 400whp on street tires? (BlueHatch00)
yeah if you run on those tires with that much power you will not hook until fourth gear guaranteed. Id say but a bigger tire on there and see how that works
Old Sep 5, 2003 | 01:04 AM
Tofurky's Avatar
just control your right foot.
you might even get better times turning down the boost a bit until you can afford some nice tires.
Old Sep 5, 2003 | 04:35 PM
18G_prelude's Avatar
Jsut curious, which BFG's do people like better? the G-force T/A drag radials or the Comp T/A radials?
Old Sep 6, 2003 | 06:00 PM
V-SPEC 1's Avatar
Default Re: (18G_prelude)
G-force Grab like slick, broke right axle after 3 runs.
Old Sep 8, 2003 | 05:13 AM
Default Re: (boostedb20vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedb20vtec &raquo;</TD></TR><TR><TD CLASS="quote">G-force </TD></TR></TABLE>
agreed, I went 12.0@115 this weekend with then. Those things work wonders.
Old Sep 8, 2003 | 08:24 PM
smokey2.0's Avatar
Default Re: (autoEXturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by autoEXturbo &raquo;</TD></TR><TR><TD CLASS="quote">
agreed, I went 12.0@115 this weekend with then. Those things work wonders.</TD></TR></TABLE>
what was your 60' times?
Old Sep 8, 2003 | 10:07 PM
Bill W's Avatar
Agreed on the azenis. In my hatch, I have them on the street tires. They spin 1st, 2nd, 3rd, and most of 4th gear (stock GSR transmission).
Mark, I recommend looking at an LS transmission instead of your ITR. Swap the diff into it. Your final drive is making your tire spin worse if you plan to stick with the factory sized tire.
G-force drags are much better than the comp drags, and either of these is much better than the Nitto garbage in my opinion..
Old Sep 8, 2003 | 11:42 PM
V-SPEC 1's Avatar
Default Re: (PFI pros)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PFI pros &raquo;</TD></TR><TR><TD CLASS="quote">Agreed on the azenis. In my hatch, I have them on the street tires. They spin 1st, 2nd, 3rd, and most of 4th gear (stock GSR transmission).
G-force drags are much better than the comp drags, and either of these is much better than the Nitto garbage in my opinion..</TD></TR></TABLE>
Exactly.
Old Sep 9, 2003 | 06:30 AM
01ITR#700's Avatar
Thanks for all the info.
FWIW I made one pass with my current setup on Sunday, closer to 350whp though. I got horrible wheelhop and a horrible 2.3 60ft. time. I still managed a 12.821 @ 118MPH That is at nearly 6000 ft. in elevation at Bandimere Speedway in Colorado. The time and trap obviously indicate there is much more potential in the car.
Thanks
Mark
Congrats on your run on Sunday Bill, that was amazing.
Old Sep 9, 2003 | 07:38 AM
DIRep972's Avatar
Smarter than you
Default Re: (01ITR#700)
Best thing for luanching on street tires is just getting the practice. Its not like slicks where you can just floor it and dump the clutch. 12.8 aint too bad on azenis get some bfg's and w/ that trap speed you should go low 12's if u can drive.
Old Sep 9, 2003 | 05:03 PM
Rhman19's Avatar
I was pretty shocked to see that time when I was there. Are those the new bfg's I guess? What 60' like someone else asked?
Old Sep 9, 2003 | 05:32 PM
prelude beast's Avatar
Default Re: (Rhman19)
autoexturbo do you have any video of the 12.00 run on street tires.
Old Sep 9, 2003 | 06:32 PM
Lightning Lover.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 18G_prelude &raquo;</TD></TR><TR><TD CLASS="quote">Jsut curious, which BFG's do people like better? the G-force T/A drag radials or the Comp T/A radials?</TD></TR></TABLE>
g-force ta's are better for fwd applications on the street, the comps are better for rwd, and are more of an all out slick(they have like 4 grooves)
Old Sep 9, 2003 | 07:19 PM
simple4012's Avatar
New User
Default Re: (Dr. Physics)
whoever said the ls tranny is insane. stick with the current tranny.
Old Sep 10, 2003 | 05:04 AM
hatchback19's Avatar
Default Re: (simple4012)
what should you tire /rim size be to get 12
17 40 205 Gforces work?
Old Sep 10, 2003 | 05:43 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rhman19 &raquo;</TD></TR><TR><TD CLASS="quote">
I was pretty shocked to see that time when I was there. Are those the new bfg's I guess? What 60' like someone else asked?</TD></TR></TABLE>
They are new to me. 225/50/15's. 60' was 2.060. No video but I will post up the pic of the time slip.
Old Sep 19, 2003 | 09:41 PM
ndtITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by simple4012 &raquo;</TD></TR><TR><TD CLASS="quote">whoever said the ls tranny is insane. stick with the current tranny. </TD></TR></TABLE>
Who would ever want an ls tranny anyway...long gearing.....ahhh...am i still does this gear ever end.................
Old Sep 20, 2003 | 01:06 AM
Tofurky's Avatar
They are new to me. 225/50/15's. 60' was 2.060. No video but I will post up the pic of the time slip.</TD></TR></TABLE>
are those on 15x7's or can you fit them on 15x6.5?
Old Sep 20, 2003 | 09:18 PM
CIVIL GSR's Avatar
what do you launch at with the gforce t/a's on street
also how often do you drive on the gforce t/a's everyday or just for a race then take them off?
brian15
Apr 19, 2010 07:19 AM
agapeBB6
Aug 28, 2006 12:55 PM
Bulldogg83
Mar 7, 2004 11:44 PM
Lost Type R
Jun 25, 2003 03:24 PM
