b18c head on obd-0 b16a questions
Old Sep 4, 2003 | 07:46 AM
conceptEG's Avatar
Default b18c head on obd-0 b16a questions
is the gsr head worth putting on a b16a?
i know the b16a head is the type r head.. same part #
but i hear people doing this head swap.. is there an advantage?
whaqt kind of hp gains or losses...
thanks
brian
Old Sep 4, 2003 | 07:54 AM
Malgerus's Avatar
Default Re: b18c head on obd-0 b16a questions (hater2587)
Higher compression. GSR stock intake manifold flows like poo though.
Old Sep 4, 2003 | 08:21 AM
conceptEG's Avatar
Default Re: b18c head on obd-0 b16a questions (Mr. S)
can i use the b16a manifold on the gsr ?
Old Sep 4, 2003 | 09:21 AM
Swift's Avatar
nope
Old Sep 4, 2003 | 10:14 AM
SiB16A's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hater2587 &raquo;</TD></TR><TR><TD CLASS="quote">
can i use the b16a manifold on the gsr ?</TD></TR></TABLE>
Nah i dont think so it doesnt line up correctly...but the b16 and the type r heads ...they are the ones that will fit....if your gonna try to put a b16 manifold on a gser ...just get a Skunk2.
Old Sep 4, 2003 | 10:23 AM
shadowstylz's Avatar
Default Re: b18c head on obd-0 b16a questions (SiB16a)
wait so mean to tell me the b16 jdm head(sir) is the same as a type r head?"
Old Sep 4, 2003 | 10:56 AM
YumVTEC's Avatar
Default Re: b18c head on obd-0 b16a questions (shadowstylz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shadowstylz &raquo;</TD></TR><TR><TD CLASS="quote">wait so mean to tell me the b16 jdm head(sir) is the same as a type r head?"</TD></TR></TABLE>
yes, they are very similar because they are made using the same cast. the difference being the ITR head is hand ported at the factory.
Old Sep 4, 2003 | 11:12 AM
Default Re: b18c head on obd-0 b16a questions (YumVTEC)
so I can say I got a type r head on a b16a block?
Old Sep 4, 2003 | 11:24 AM
Fred n J_v2.0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shadowstylz &raquo;</TD></TR><TR><TD CLASS="quote">so I can say I got a type r head on a b16a block?</TD></TR></TABLE>
if you have a type r head, then yes. only similarities are the castings. Thats IT.
Cams/Valve-train/Intake Manifold/ Mild Porting are all on the Type R head.
The 1st gen b16 head can be made to be like a type r head but stock for stock, no comparison.
Old Sep 4, 2003 | 11:45 AM
Default Re: b18c head on obd-0 b16a questions (95VXFRANK)
thank you for the clear up.
Rhymenoceros
17
Oct 10, 2006 01:35 PM
integra_type-r
Dec 23, 2004 08:15 PM
markpa2
May 18, 2004 06:13 AM
CRXEE8
Dec 8, 2003 11:00 AM
slimbo
Mar 4, 2002 10:02 PM
