EG6 JDM cluster problem?
Old Sep 3, 2003 | 10:16 PM
mr2kqql's Avatar
Default EG6 JDM cluster problem?
Actually I had the jdm cluster for awhile already but kinda lazy to know why the dimmer switch doesnt work. I did some reseach and also other ppl say that after you swap the cluster the dimmer switch no longer works on the cluster inself but others. does anyone know a trick to make it work??? or I need some kind of mod on the cluster itself?
Old Sep 3, 2003 | 10:57 PM
EG2 SiR's Avatar
Default Re: EG6 JDM cluster problem? (mr2kqql)
I have a jdm cluster in my del sol and there is no spot for the dimmer, but it did plug in.... So I just plugged it in, turned it all the way bright, and installed the cluster... The dimmer **** is hiding in my dash now
Old Sep 4, 2003 | 02:09 AM
eg_type_r93's Avatar
Default Re: EG6 JDM cluster problem? (EG2 SiR)
all the way bright is better anyways not a prob 4 me
Old Sep 4, 2003 | 05:06 AM
ComingSoon240sx's Avatar
Why would you wanna dim the glow of jdm amber?
I think eg2 sir's idea is best
Old Sep 4, 2003 | 07:26 AM
mr2kqql's Avatar
Do you guys even understand the question I am asking?????? the dimmer switch not working and not I want to dim the the glow of jdm amber, dude trial user , do you drive a honda???
Old Sep 4, 2003 | 09:06 AM
mixmastabob's Avatar
Default Re: (mr2kqql)
i don't think that you can dim the JDM amber cluster
Old Sep 4, 2003 | 11:23 AM
mr2kqql's Avatar
Default Re: (mixmastabob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mixmastabob &raquo;</TD></TR><TR><TD CLASS="quote">i don't think that you can dim the JDM amber cluster </TD></TR></TABLE>
You sure there are no ways to modifiy it?
Old Sep 4, 2003 | 11:31 AM
Jeice's Avatar
My bud has a VTi Gauge cluster with amber, and his dimmer switch works.. it should just be plug and play??
Old Sep 4, 2003 | 11:55 AM
Apex i ITR's Avatar
From: Toronto, Canada currently residing in ATL, GA, USA
Default Re: EG6 JDM cluster problem? (Jeice)
I'd like to make mine brighter and my dimmer switch doesn't work either.
Old Sep 4, 2003 | 12:21 PM
chillax's Avatar
Default Re: EG6 JDM cluster problem? (Apex i ITR)
I also have the same problem, dimmer does not work and I would like to make it a little brighter.
Old Sep 4, 2003 | 12:25 PM
mr2kqql's Avatar
you know what guys, i know that you could modifiy it but just dont know which step to start, like Jeice said , his bud VTi gauge also could adjust the dimmer
Old Sep 4, 2003 | 12:27 PM
tiki todd's Avatar
who cares bro let that **** shine!
Old Sep 4, 2003 | 01:02 PM
cccya's Avatar
Default Re: EG6 JDM cluster problem? (jdmtoadstool)
i have the VTi and the dimmer switch does not work. don't care, don't need to change my lights all the time anyways....
93Civic_hb
Apr 4, 2008 03:50 AM
Feelseg
Mar 8, 2006 04:56 PM
itsJDMyo
15
Dec 30, 2004 09:47 PM
DOHCTOR
Aug 16, 2001 01:14 PM
