vtec light???
Old Sep 3, 2003 | 09:55 PM
toooslow's Avatar
Default vtec light???
is it possible to hook up little 12volt light to vtec somehow so when vtec comes on it lights up?
Old Sep 3, 2003 | 10:14 PM
Kamin's Avatar
Default Re: vtec light??? (whiteinteg95)
yes but why
Old Sep 4, 2003 | 03:18 AM
.xcalibur.'s Avatar
yes its possible. just make sure you have it in series with a resistor so the LED doesnt drain all the voltage from the VTEC solenoid. Otherwise you get the light but no vtec. boo!
Old Sep 4, 2003 | 11:23 AM
toooslow's Avatar
Default Re: vtec light??? (.xcalibur.)
could you expain more on the resistor and in-series
Old Sep 4, 2003 | 02:05 PM
.xcalibur.'s Avatar
just search the netfot vtec light and you will get back directions for its installation and which resisotr to use and placesto mount it.
Old Sep 5, 2003 | 02:17 AM
mattb16a1civic's Avatar
its kinda funny that you posted this, i actually saw a vtec light on ebay, it says vtec on it and goes in ek civic in the dash in one of the oval spots on the guage cluster blue and red and probably more colors says it will increase your 1/4 times, lol so funny, look it up if you really feel the need for a rice mod.
Old Sep 18, 2003 | 03:08 AM
goodbyegti's Avatar
increase your 1/4times!!! I hate it when people put stupid stuff like that, i always mail them taking the ****!
Old Sep 18, 2003 | 08:50 AM
axhandler's Avatar
Yes...its easy...run a wire from vtec solenoid to the 12v LED (which draws hardly and current and will not cause the vtec solenoid to malfunction) and run a ground from the LED to the chassis. All done. Search here and you will find exact directions.
I got a green LED from Radio Shack that cost like $2 and some wire I had laying around...wired it up and put the LED behind one of the spare ovals on my cluster and it's been working fine for about 3 years. If my vtec solenoid ever does stop working I will know.
Old Sep 18, 2003 | 10:27 AM
B18C_EJ8's Avatar
Default Re: vtec light??? (axhandler)
You could also buy the new VAFC 2, which has a build in VTEC light... The toggle wheel changes color when VTEC crosses over.
Old Sep 18, 2003 | 11:27 AM
axhandler's Avatar
Default Re: vtec light??? (B18C_EJ8)
You don't have to buy the new version for that...on the current one in monitoring mode you can turn on Vti, that's the signal from the ECU to the VTEC solenoid, and the V-AFC will say "off" or "on."
Old Sep 18, 2003 | 02:15 PM
B18C_EJ8's Avatar
Yeah, but what if he can't read? The words "On" And "Off" wouldn't be of much use to him...
Old Sep 18, 2003 | 02:25 PM
slvrcivic97's Avatar
Default Re: (B18C_EJ8)
I used these but I think it might be better to wire to the vtec solenoid rather than the ecu. I did the ecu and it's not working. I'm going to just hook it up to the solenoid. Here you go buddy:
http://www.hazone.com/hvlight.htm
Old Sep 18, 2003 | 03:02 PM
BuddhaSiR's Avatar
Default Re: (slvrcivic97)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slvrcivic97 &raquo;</TD></TR><TR><TD CLASS="quote">I used these but I think it might be better to wire to the vtec solenoid rather than the ecu. I did the ecu and it's not working. I'm going to just hook it up to the solenoid. Here you go buddy:
http://www.hazone.com/hvlight.htm </TD></TR></TABLE>
what difference does it make. are you not splicing into the same wire?
Old Sep 18, 2003 | 04:26 PM
luti's Avatar
Default Re: (BuddhaSiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BuddhaSiR &raquo;</TD></TR><TR><TD CLASS="quote">
what difference does it make. are you not splicing into the same wire?</TD></TR></TABLE>
It shouldn't make a difference, it's the same wire. I did mine near the ecu and ran the led into my cluster and it has been working perfectly for about 2 years.
Old Sep 18, 2003 | 04:38 PM
RCautoworks's Avatar
Default Re: (luti)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by luti &raquo;</TD></TR><TR><TD CLASS="quote">
It shouldn't make a difference, it's the same wire. I did mine near the ecu and ran the led into my cluster and it has been working perfectly for about 2 years.</TD></TR></TABLE>
Yes, if you go by the spot and not the color of the wire. I forgot if obd2 or obd0 changes the vtec wire once it runs into the fire wall. It changed to orang, so don't always go by just the color.
Old Sep 19, 2003 | 05:31 AM
axhandler's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, but what if he can't read? The words "On" And "Off" wouldn't be of much use to him... </TD></TR></TABLE>
LOL...good point...
If your not sure about the color of the wire...look at the wire going to the solenoid...it's exactly the same wire...it goes directly to the ECU.
Or you can go to the online instruction manual for the VAFC and find the exact pin location for your ECU. I know there are assloads of places to get this info but this one is easy.
Look at pages 16 and 17 of the pdf... http://www.apexi-usa.com/produ...c.pdf
h22a_93accord
May 20, 2008 09:09 AM
jdmwannabe3
25
Apr 14, 2006 08:57 PM
J's GS-R
Feb 23, 2006 05:45 PM
Pineapple Devil
Oct 16, 2002 03:41 PM
DV98CVC
Sep 6, 2002 10:11 AM
