EVAP? Do you need it?
Old Sep 3, 2003 | 09:30 PM
dmecarboy's Avatar
Default EVAP? Do you need it?
Just curious if it's necessary to have? thanks!
Old Sep 4, 2003 | 06:35 AM
JimBlake's Avatar
Default Re: EVAP? Do you need it? (dmecarboy)
It's required by EPA for gasoline evaporating from the tank. Since sometime in mid-'70s ALL emmisions are included, not just the tailpipe.
If you plug it all up, you need to vent your gas tank somehow. Before EVAP systems, the gas cap had a small vent like the one in your lawnmower. It's probably not worth the effort, because I don't think the EVAP system hurts performance anyway.
Old Sep 4, 2003 | 09:50 AM
RyanEJ8's Avatar
Default Re: EVAP? Do you need it? (JimBlake)
It is extra weight and space in the engine compartment though.
Old Sep 4, 2003 | 11:31 AM
Perfectionist's Avatar
Default Re: EVAP? Do you need it? (RyanCivic2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote">It is extra weight and space in the engine compartment though.</TD></TR></TABLE>
You'd lose more weight by taking a good dump before you drive.
Old Sep 4, 2003 | 11:46 AM
RyanEJ8's Avatar
Default Re: EVAP? Do you need it? (Perfectionist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Perfectionist &raquo;</TD></TR><TR><TD CLASS="quote">
You'd lose more weight by taking a good dump before you drive.</TD></TR></TABLE>
LOL, that could be true, but I see alot of people taking USEFUL things off that weight less than that even.
Old Sep 4, 2003 | 02:11 PM
bruthaboost's Avatar
Nope. Took mine out when I dropped a jdm engine in. The tb doesn't allow for one. I just put a check valve on the line that normally vents the gas tank.
MattyG
Aug 2, 2006 10:55 AM
Skeletor_1320
Apr 28, 2006 04:59 PM
mattmw88
Mar 28, 2004 12:08 AM
MrIllegalX
34
Feb 21, 2004 10:02 AM
fastwanabe
May 26, 2003 03:38 PM
