Zeal or ....
Okay,
I think I have decided on a suspension, Zeal S6. Is there any other suspension that I should look at that is comparable. I was looking at the Tein RAs. But the specs on the Zeal are just a little better. Is there any other suspension I should check out before I put down the cash?
If you are set on the JDM type suspn's then either will be fine, but i would look into a custm Koni/eibach set-up, or Bilstein with ground controls with custom rates. I am getting these. good luck
Bryan
Bryan
TEIN N1 isn't very streetable I think depends on the spring rate and adjustment. They might cost a lot more than S6 also.
ZEAL S6 will be a very good choice for daily driving and some crazy road racing & track days. U will love that!
Has anyone bent their aluminum shocks on the streetz? If so how fast were you going and what you hit? This is the last determining factor if I should get the Zeal S6s. Thanks
