miles on oil?
I use the same and go 5k between changes. That's one of the advantages to synthetics, more miles between changes.
In the end, it's whatever helps you sleep well at night. Earlier than 3K is a waste, so anything after that is fine.
Cheers,
Roy
Cheers,
Roy
well its reccomended that you change it every 3 months or 3000 miles whichever comes first...they usually reccomend that for extreme temps...high heat low low temps....personally i burned oil pretty consistantly so i just changed it every 3 months
pydwy213
36
Sep 29, 2005 09:52 AM
