89 CRX Si wont start HELP!!!
Old Sep 3, 2003 | 05:32 PM
c2etalon's Avatar
Default 89 CRX Si wont start HELP!!!
My crx si (beater) has been having some problems. It takes for ever to get started, I have to crank it for like 15 secs before it finally starts and it bogs like hell at first. I did a full tune up (cap, rotor, plugs, wires) and just did a new 02 sensor. I replaced the fuel pump like 5 months ago and tonight it just kinda bogged out then when I was hitting the gas nothing happend. I then drifted into a parking lot and it died. I tried to start it but it wouldnt start at all. It turns over and starts for a milli second then dies? What should I check...?????
Help guys...
Aaron
Old Sep 3, 2003 | 06:08 PM
mwkirchner's Avatar
Default Re: 89 CRX Si wont start HELP!!! (c2etalon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c2etalon &raquo;</TD></TR><TR><TD CLASS="quote">My crx si (beater) has been having some problems. It takes for ever to get started, I have to crank it for like 15 secs before it finally starts and it bogs like hell at first. I did a full tune up (cap, rotor, plugs, wires) and just did a new 02 sensor. I replaced the fuel pump like 5 months ago and tonight it just kinda bogged out then when I was hitting the gas nothing happend. I then drifted into a parking lot and it died. I tried to start it but it wouldnt start at all. It turns over and starts for a milli second then dies? What should I check...?????
Help guys...
Aaron</TD></TR></TABLE>
Might be the throttle body. If memory serves me right the TPS is connected to it and is NOT replaceable ... other then with the throttle body. The description of your problem leads me to think that it may be bad.
Old Sep 3, 2003 | 06:09 PM
Honda Bob's Avatar
I would for sure change the Main Relay. Even if that is not the problem, it will go soon enough anyway.
Old Sep 11, 2003 | 10:39 PM
user 996328629's Avatar
Default Re: 89 CRX Si wont start HELP!!! (Honda Bob)
Well the rotor fell off thats why it didnt start. But now its still doing the same damn thing. I replaced the fuel filter to no avail. The check engine light comes on when Im on it and when it clicks on it feels like it hits vtec, like it corrects itself or somthing. Anyway, when I start off in 2nd gear, it pops and barely moves. Anymore help?
Thanks
Old Sep 11, 2003 | 10:45 PM
Vinceg99's Avatar
Default Re: 89 CRX Si wont start HELP!!! (Swags04)
Possibly a bad distributor bearing. Its probably on its way out thats why your getting the problems.
Also someone above mentioned that the TPS is not replacable unless you get a whole throttle body that isnt true it just LOOKS like it cant be taken off whats holding it in are break off screws so after a certain amount of pressure the head breaks off if you need to replace it just grind a notch in it and unscrew it that way.
Old Sep 11, 2003 | 11:32 PM
Default Re: 89 CRX Si wont start HELP!!! (Vinceg99)
I have a spare distributer off my last civic. Should I just put the whole thing on and see what it does? Doesnt this sound like a fuel prob?
Let me know
Old Sep 11, 2003 | 11:39 PM
Vinceg99's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Swags04 &raquo;</TD></TR><TR><TD CLASS="quote">I have a spare distributer off my last civic. Should I just put the whole thing on and see what it does? Doesnt this sound like a fuel prob?
Let me know</TD></TR></TABLE>
Well as long as its an Si dizzy yeah why not try it??
SotV BiG Poppa
May 14, 2012 03:54 AM
CRXDragon
May 26, 2010 01:36 PM
dc2leftovers
Jul 15, 2007 04:04 PM
newtothascene
Nov 4, 2004 11:52 PM
B_CRUZ!
Jul 10, 2002 08:13 AM
