Who has this nice new trunk rattle?
New User
ITs a 2001. I have had this god awful rattle coming from the trunk area. I thought maybe it was the spart tire or the jack not tightned down but it wasn't. I even though ok maybe the seals need some luberication..So i used Zymol seal protectant or whatever the hell it is called. That didn't do it. I really think it's coming from inside the trunk lid itself, kind of like something is hitting against it. Anyone have a suggestions or experience pn what it could be?? This is really ******* annoying.
Have you pulled out the plastic in the rear to see if any of the wires for the wiper motor have come loose or anything? That's all I can think of that's IN the trunk lid itself.
the hatchback cover is what it is. One of the metal clips that holds it in has come loose and it rubbing against the metal part of your hatch, this is exactly what mine was.
HOW TO SOLVE:
Pop your hatch. On the underside of the hatch (interior side) there is a plastic cover, pry it off, don't worry, you won't break anything. Then fix al lthe clips so they are bent properly, re-install and take for a test drive.
-ryan
HOW TO SOLVE:
-ryan
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegasaurus »</TD></TR><TR><TD CLASS="quote">the hatchback cover is what it is. One of the metal clips that holds it in has come loose and it rubbing against the metal part of your hatch, this is exactly what mine was.
HOW TO SOLVE:
-ryan</TD></TR></TABLE>
Ahh i thought that could be it, if it wasn't in the trunk lid itself. So just pull it right off?
what year is yours?
HOW TO SOLVE:
what year is yours?
If it's not the cover that was already mentioned, have someone drive the car while your crawl around in the back and listen to where it's coming from.
It could also be the swaybar endlinks.
Cheers,
Roy
Cheers,
Roy
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rapid_roy »</TD></TR><TR><TD CLASS="quote">If it's not the cover that was already mentioned, have someone drive the car while your crawl around in the back and listen to where it's coming from.
Cheers,
Roy</TD></TR></TABLE>
Yeah i looked into the sway bar..being i put an ITR in about a ywar and half ago. I thought maybe it had come loose, but it wasn't..
Cheers,
i used to have a rattle that drove me crazy. it turned out to be on the c pillar where the plastic overlaps. double sided tape made it all better.
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RayB »</TD></TR><TR><TD CLASS="quote">Yep I'm with him. Mine was the latch. Wrapped it in electrical tape and two years later, still no rattle.</TD></TR></TABLE>
just wrap the whole "U" part in tape?
New User
Thats exactly what it was......
thanks guys
thanks guys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nighthawk GS-R »</TD></TR><TR><TD CLASS="quote">
thanks guys</TD></TR></TABLE>
That's what I was going to suggest, mine did the same thing. Nothing a little black electic tape couldn't fix
what year is yours?</TD></TR></TABLE>
The trick is to find out where a clip is and get 1 clip off, slip your hand in there and just pull the thing down as hard as you can, it'll come off pretty easy, nothing will break because its all plastic that's pretty soft. i have a '94
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rick »</TD></TR><TR><TD CLASS="quote">I sometimes get a slight rattle from the drivers door area. Anyone else have that?</TD></TR></TABLE>
does that happen when your elbow is on the arm rest area?
ive been hearing a very unusual rattle coming from the inside trunk area.. sometimes it louder than other times..
it could be my cpillar, rear strut bar, or my hatch cover..?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Link0 »</TD></TR><TR><TD CLASS="quote">I have the same problem. Check your swaybar end links and sway bar bushings. Mine is the bushing. Anyone know where to get good bushings for a 98 teggy?</TD></TR></TABLE>
Well I'm not exactly sure where to get them but I do suggest getting Energy Suspension bushings wherever you can find em... but expect to pay a little bit of $$
