Difference Between Injectors
Old Sep 3, 2003 | 10:19 AM
MaaseyRacer's Avatar
Default Difference Between Injectors
So I am finally starting my b16 build, and I was wondering what if there is any difference between b16 and 4th gen SI injectors? The reason I am asking is that I have a set of 4th gen SI injectrors lying around, and I am piecing together my B16, so I am missing injectors. Is there any real benefit to having B16 injectors or is it a subtile differnece.
Thanks
Old Sep 3, 2003 | 10:34 AM
zCivic's Avatar
Default Re: Difference Between Injectors (MaaseyRacer)
all civic/integra injectors are 240cc. The difference is peak/hold and saturated. If there from a 88-91 MPFI there peak/hold low impediance while 92+ are high. p/h uses the injector resistor box. yours will work without any problems.
Old Sep 3, 2003 | 10:35 AM
roadawg's Avatar
I would really like to know myself, my b16 was installed 2 weeks ago and the injectors are clogged causing hesitation.
I was thinking any obd -0 injectors would work, can someone confirm this. TIA
Old Sep 3, 2003 | 11:42 AM
zCivic's Avatar
Default Re: Difference Between Injectors (SiRWanabe)
yes they will work. If you have a OBD0 injectors now you can use any peak/hold honda injectors there all 240 cc's except 92-96 prelude vtecs which were 340's. they all use the resistor box. You can also use other injectors but may require more work ex. 1st gen DSM, mustangs, toyotas etc...... If you get some saturated injectors you would need to remove the injector resistor box and split the yellow wire to each of the 4 injectors or make a jumper for this
h2point2
Sep 17, 2007 07:56 AM
dkk119
Mar 18, 2006 11:36 AM
o'malley_808
Jun 7, 2005 04:00 PM
GreenEX
Apr 1, 2004 04:32 PM
infinkc
Jan 24, 2002 08:19 AM
