Injector tick??
Old Sep 3, 2003 | 09:00 AM
MissMyHonda's Avatar
Default Injector tick??
So I get the odd ticking noise, first I thought valves were just out of spec, so I got a valve adjustment done. Still there. So i did a comp test, everything's good. Then i stuck my head under the hood and it def. sounds like it's comming from the injector/IM area...is this normal, it's quite loud and not a bent valve, it's constant. Doesn't change when RPMs increase. Very odd. Am I crazy?
Old Sep 3, 2003 | 09:02 AM
Bbasso's Avatar
Default Re: Injector tick?? (JoesTypeS)
My R has a tick tick tick tick sound from the fuel rail area- Always had it...
For the most part the Rs have it, common thing.
Old Sep 3, 2003 | 09:05 AM
Ferrell's Avatar
Default Re: Injector tick?? (Bbasso)
my injectors are loud as well.
Old Sep 3, 2003 | 09:16 AM
Default Re: Injector tick?? (Ferrell)
That makes me feel a bit better. Anyone ever used that "snake oil" fuel injector cleaner, does it acutally work? Or is it really just snake oil.
- joe, who believes the stupid STP commericials on Speed Channel
Old Sep 3, 2003 | 10:30 AM
RaVAGE00's Avatar
New User
Why do they tick..... is this normal injector operation or just a problem related to the B18C5?
Old Sep 3, 2003 | 10:53 AM
RTW DC2R's Avatar
Default Re: Injector tick?? (RaVAGE00)
its normal. and mine are loud as hell on 370cc injectors. think if it like this: take your garden hose with spray nozzle, and spray it full blast. does it make a noise? yes it does. now take that same hose, and squeeze and release the trigger really fast. does it still make noise? yup. its just the sound of pressure pushing the liquid from its container.
Old Sep 3, 2003 | 10:58 AM
RaVAGE00's Avatar
New User
Default Re: Injector tick?? (RTW DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2 &raquo;</TD></TR><TR><TD CLASS="quote">its normal. and mine are loud as hell on 370cc injectors. think if it like this: take your garden hose with spray nozzle, and spray it full blast. does it make a noise? yes it does. now take that same hose, and squeeze and release the trigger really fast. does it still make noise? yup. its just the sound of pressure pushing the liquid from its container. </TD></TR></TABLE>
If this is the case, why wasnt this "ticking" noticable when the R was new...
Old Sep 3, 2003 | 11:00 AM
BABY NSX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RaVAGE00 &raquo;</TD></TR><TR><TD CLASS="quote">
If this is the case, why wasnt this "ticking" noticable when the R was new...</TD></TR></TABLE>
My injectors have been ticking away from day one...
Old Sep 3, 2003 | 11:08 AM
Bbasso's Avatar
"problem related to the B18C5?"
Not a problem, just how it is.
Old Sep 3, 2003 | 11:14 AM
Splat's Avatar
Collector-o-Guns and Drinker
I thought my Hype R ticked loud... Until I got the Turbo Pig
Big sprayers + five of them = lots of noise.
Old Sep 3, 2003 | 11:18 AM
RTW DC2R's Avatar
Probably for the same reason it no longer has that new car smell. its broken in.
RaVAGE00's Avatar
New User
Default Re: Injector tick?? (BABY NSX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BABY NSX &raquo;</TD></TR><TR><TD CLASS="quote">
My injectors have been ticking away from day one...</TD></TR></TABLE>
Baby - that isn't your injectors making noise, its your brain...
Old Sep 3, 2003 | 04:27 PM
I'm sure they've been doing it all along, it's just one of those things you notice as you get more used to every little noise the car makes and you go "oh **** what was that"
Old Sep 3, 2003 | 05:10 PM
RaVAGE00's Avatar
New User
Default Re: (JoesTypeS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JoesTypeS &raquo;</TD></TR><TR><TD CLASS="quote">I'm sure they've been doing it all along, it's just one of those things you notice as you get more used to every little noise the car makes and you go "oh **** what was that"</TD></TR></TABLE>
I guess.
Old Sep 3, 2003 | 05:39 PM
MiraiZ's Avatar
Default Re: (RaVAGE00)
Injectors should tick to some degree as the ball and spring expands and contracts when the injector pulses....however, they shouldn't be so loud that you can here it from inside the car. If its that loud, you may want to clean them...plain jane in-tank injector cleaner for the parts stores should be ok for starters, but if they are still loud after that, it may need to be cleaned and balanced professionally.
Old Sep 3, 2003 | 06:29 PM
jdmspoonitr's Avatar
Default Re: (MiraiZ)
&lt;-----Can here ticking noise from inside of the car, but only with the silencer in.
Old Sep 3, 2003 | 08:14 PM
Rory Breaker's Avatar
Default Re: (jdmspoonitr)
My DSM injectors are ridiculously loud. You cant hear them in the cabin, but they are very loud outside of the car.
Old Sep 4, 2003 | 08:34 AM
99blusi's Avatar
Default Re: (newgsrdriver)
My RC 310's are pretty loud...I thought it was the mobil 1 on the last oil change/turbo install...but it's definately the injectors.
Old Sep 4, 2003 | 09:04 AM
bgod's Avatar
Default Re: (99blusi)
my friend's totally stock 2001 ITR has ticked from day one. nothing you don't get used to.
my old 850cc rc injectors sounded like a honda motor that hadn't had it's valves adjusted in 150k. ridiculously loud and never stops. then the aeromotive pump. need damn ear plugs.
Old Jul 5, 2020 | 12:32 AM
Jakob Knuth's Avatar
All I have to say is make sure it's not your valves. Yes, injectors tick but if you hear it coming from your fule rail it could be your number one valve, and generally unless you are running like 1000cc injectors you should never hear the tick from injectors.
92civic4drb18b1
Jun 22, 2011 01:55 PM
ASpec818
Feb 25, 2003 02:34 PM
SixPAK
10
Feb 13, 2003 12:29 AM
LeftCorner
Aug 11, 2002 07:26 PM
