2000 Civic SI oil consumption
Old Sep 3, 2003 | 08:53 AM
CardDealer's Avatar
Banned
Default 2000 Civic SI oil consumption
Modified by CardDealer at 4:01 PM 11/17/2006
Old Sep 3, 2003 | 09:38 AM
crazy eyez killa
Guest
Posts: n/a
Default Re: 2000 Civic SI oil consumption (schlit)
Do you have synthetic oil? That's what my problem was. I switched from regular oil to full synthetic at about 20k miles and it caused my valve stem seals in my 99 Si to start leaking.
Next time you have your head opened up for valve springs, cams, whatever, replace your valve stem seals. It's a $50, $60 fix.
Old Sep 3, 2003 | 11:02 AM
MikeMAN's Avatar
if you drive it hard, it is perfectly normal
mike
Old Sep 3, 2003 | 01:49 PM
crazy eyez killa
Guest
Posts: n/a
Default Re: 2000 Civic SI oil consumption (MikeMAN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeMAN &raquo;</TD></TR><TR><TD CLASS="quote">if you drive it hard, it is perfectly normal
Losing oil is normal? Yeah, right! Tell me where that quart goes every 2000 miles.
Old Sep 3, 2003 | 03:09 PM
CardDealer's Avatar
Banned
Default Re: 2000 Civic SI oil consumption (CivicCLMT)
Old Sep 3, 2003 | 03:23 PM
LudeyKrus's Avatar
This is from my experience....
W/ honda's high-revving VTEC engines, it will naturally lose some oil, especially when driven hard. I've seen it on civic si's (b16), as well as on preludes (H22), which were all new.
It IS normal, and a quart between oil changes is NOT bad, considering you bring it into VTEC often.
And on the other guy's comment that switching to synthetic caused his valve stem seals to leak:
It was not the seals that started leaking, it was the change in viscuosity of the oil. In old VW Beetles, switching to synthetic causes them leak MUCH more, since they naturally leak easily.
It's the fact that the oil becomes "thinner", so that it can flow through much smaller openings easier. That is why you lose a good bit of oil in an engine runnig synthetic oil.
Old Sep 3, 2003 | 05:35 PM
MikeMAN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicCLMT &raquo;</TD></TR><TR><TD CLASS="quote">
wow, u have a lot of learning to do it seems..i thought this was basic stuff. your engine isn't a PERFECT seal after so many miles, and if he has a decent amount, especially with hard driving.....there u go
mike
Old Sep 3, 2003 | 07:43 PM
VTECorona's Avatar
Just about everyone that I talk to with a gsr says they burn about a quart between 3000 mile changes using mobil 1 synthetic. I'm going to pull the ol' switcharoo and try castrol syntec for a change, I heard it doesn't burn.
Old Sep 4, 2003 | 03:27 AM
CardDealer's Avatar
Banned
Old Sep 4, 2003 | 11:07 AM
PupaScoopa's Avatar
My B16 burns about 1 quart of oil every 3000 miles as well... it did that since day 30 when I changed the oild to Mobile 1. Nothing out of the ordinary.
lolv8s
K Series
Apr 14, 2016 01:29 PM
kidcruze
Apr 7, 2008 06:09 PM
gdub604
14
Dec 24, 2007 07:31 PM
GocosblucivicSi
Nov 4, 2004 11:48 AM
crazy eyez killa
Nov 15, 2003 05:32 PM
