How hard to install power door locks???
Old Sep 3, 2003 | 08:48 AM
SuicideSlide's Avatar
Default How hard to install power door locks???
If I wanted to install power door locks into my 95 dx would it be easier to use stock honda ones or go out and buy an aftermarket kit? Im installing an alarm soon an would really love to have key less entry with my setup.
thanks
Drew
Old Sep 3, 2003 | 08:54 AM
WRX Mike's Avatar
Default Re: How hard to install power door locks??? (Tur*bLu)
well first of all you have to run wires into the door. how comfprtable are you doing that? Second yoyu have to install the auctuator itself which isn't really that bad. The only really bad part is running the wires for the door locks. Or you could use yourspeaker wire and some diodes. But that is usually more trouble then it's worth.
Old Sep 3, 2003 | 08:57 AM
Default Re: How hard to install power door locks??? (redhat778)
What sort of wires will I need to be running through the doors?
Old Sep 3, 2003 | 09:09 AM
B18C_EJ8's Avatar
16 gauge speaker wire will work fine.
Old Sep 3, 2003 | 09:39 AM
DevLishPlaya's Avatar
up i want to do this as well, has anyone have the instructions to do this?
Old Sep 3, 2003 | 11:38 AM
salbaje's Avatar
stock ones are easy to put on just 2-3 screws and about 3 wires
Old Sep 3, 2003 | 12:19 PM
Default Re: How hard to install power door locks??? (salbaje)
How reliable are the stock ones? Meaning would it be safe for me to go to my local junkyard and pick up a set from an hold 92-95 civic?
Old Sep 3, 2003 | 03:11 PM
civicr97's Avatar
the actuators cost about 20 bucks. do you have an alarm? if so best buy will do them for 70 a door with the actuator and they will warranty their work.
Old Sep 3, 2003 | 03:14 PM
boostsohfast's Avatar
Default Re: How hard to install power door locks??? (civicr97)
I installed a set of reverse polarity actuators and it turned out to take so much longer than I expected with wiring the relays with the alarm, and getting a good mounting area for the actuator itself without interfering with the door panel. Sounds simple but can be a pain in the ***.
Pure Sol
Audio / Security / Video
Apr 9, 2009 06:10 PM
SHG_Beans
Jan 8, 2006 12:30 PM
CivHatchH22
Mar 20, 2004 12:51 PM
spunky424
Mar 2, 2004 04:10 PM
Airbag Club
Nov 24, 2002 04:45 PM
