Help what does this noise mean?
I changed my oil, and when i was done my clutch started making a funny noise. When i push the clutch in it squeeks. I have a hydro clutch. could it be the TOB? i checked my clutch fluid and it was a little low. Now my next question is, should there be a pressure float in my tranny reservoir, like there is in the brake fluid reservoir? Can i just bleed the clutch to make the noise stop? any sugestions
my clutch squeaks, my dads clutch squeaks (2001 LX), its normal...i took it to the honda dealer and all they did was lubed it and it still squeaks...how bad it is really depends on the temperature...its nothin to worry about tho
I had a squeak, so I just sprayed everything that moved with lithium grease and it worked. I don't know if it's the right thing to do , but it worked
its a squeak coming from the clutch area when u press it in or let it back out...hondas are full of cabin noises i cant count how many mine has...they were horrible with sound deadening when they were NEW and they are even worse as time goes on...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MickSiR »</TD></TR><TR><TD CLASS="quote">what's a clutch
a female *****
a female *****
Tokyo_X-treme_Racer
18
Jan 28, 2004 11:48 AM
