What will I need? (installing new parts)
Ok, here's what I got going in:
exhaust header
clutch/pp/flywheel
intake manifold
transmission
I picked-up a new intake manifold gasket at honda, also got new TO/pilot bearings for the new clutch set-up. I need to go pick-up a piping donut for the header.
Do I need to pick up any other small misc parts for these installs? TIA
Oh, one more thing, I gotta get a new driver's side cv joint, should I install that at the same time? (clicks a lil, but I could sit on it for a bit...kinda tight on money, but if it's a good idea to do it now, I could push that). Thanks homies.
exhaust header
clutch/pp/flywheel
intake manifold
transmission
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pho Real »</TD></TR><TR><TD CLASS="quote">Did you get the Alignment tool for the Clutch?</TD></TR></TABLE>
Yessir. Alignment tool good to go.
dont forget a tb gasket too. ur not supposed to reuse the exhaust mani gasket at the head, but ive installed headers w/o getting any leaks. get some anti-seize for the head bolts too.
sockvtec
Oct 16, 2005 03:49 PM
