TECH: My car died while driving!
Old Sep 2, 2003 | 01:16 PM
Integra_B18B's Avatar
New User
Default TECH: My car died while driving!
Ok, I have a 1998 Integra LS with 105,000kms on it.
Here's what happened:
I was driving about 50km/hr then all of a sudden my car just dies. No power to the car and no power steering and NO I didn't stall!
So I pull over to the side then wait for a bit then try starting up the car again, then it starts up fine!
What gives? Some people say its the COILS I need to change. I'm kinda freaked out cause what if I was in heavy traffic or something.
HELP PLS!!!
Old Sep 2, 2003 | 01:20 PM
VTECorona's Avatar
Default Re: TECH: My car died while driving! (Integra_B18B)
New rotor, cap, plugs, plug wires couldn't hurt.
Old Sep 2, 2003 | 01:31 PM
New User
Default Re: TECH: My car died while driving! (VTECorona)
I've already changed my cap, rotor, plug wires and change my plugs every 25,000kms so that's not the problem.
Old Sep 2, 2003 | 02:14 PM
Crazydave's Avatar
things to check
Spark
Cap Rotor wires coil plugs
Fuel
fuel pressure
fuel pump
fuel filter
Battery
Make sure it's at least 12v not running
and hold >9.7v under a load
alternator
should be charging 14.4v running
belts (timing & alternator, etc)
make sure they are there and are in good shape no cracks
what were the exact condiditons when you car died
Old Sep 2, 2003 | 02:16 PM
Crazydave's Avatar
Default Re: TECH: My car died while driving! (Crazydave)
are you throwing any codes?
did you car overheat?
do you have a voltmeter on your car
Old Sep 2, 2003 | 02:36 PM
New User
well, after my car died i turned on the "flashers" and pulled over as fast as i could doing it safely. then i checked under the hood and everything seemed fine. timing belt, etc.....
i changed my cap, rotor, plug wires not too long ago. i was thinking its the battery but why did my car start up again afterwards????
i'm totally lost and confused about this.
so far people say it could be my alternator or the coils......
New User
no codes and no overheating....
Old Sep 2, 2003 | 03:00 PM
CRXDrew's Avatar
Dude, the same thing has been happening to my CRX. I swapped a new SOHC vtec head on it and it won't stay on. It will start just fine but it just loses power and dies. I'm going to check my ignitor and ignition coil, you should do the same.
Andrew
Old Sep 2, 2003 | 04:01 PM
Regular Series's Avatar
Are your battery connections secure? Sometimes they get loose. I've had that happen to me before, and it was intermittent.
Old Sep 2, 2003 | 04:46 PM
5thgencivic's Avatar
Same thing happened to me, only I was on a narrow road on a steep hill. So I had to roll back until I could turn around then coasted back down to my house. In my case it was a tank of bad gas. Gas treatment couldn't hurt if you have tried some other things.
Old Sep 2, 2003 | 05:09 PM
Turbo12acer's Avatar
most of the time its bad gas. Cleaning your fuel lines might be a good idea too. check your dizzy too.
admess188
Aug 13, 2011 07:29 PM
milanocivic
Feb 20, 2009 08:26 PM
eternity-type-r
Feb 17, 2009 02:27 PM
asiansgoweeee
Jul 14, 2004 08:26 AM
Turbo D17
13
Jun 3, 2004 08:00 PM
