6'' sub, who?!
yes that is right, hmm.. do you know specs off hand.. i was thinking of getting one of the xtant 1.1's and putting that on waht ever one I get... waht do you think of that?
Focal Utopia Line 5WS
136mm (5 3/8") subwoofer for small bass reflex enclosure
40mm (1 3/8") voice coil 4" magnet
5ohm impedance
max power handling 160 watts nominal power handling 80 watts
sensitivity 87 db
freq response 45hz- 2.5 khz
i can get it for u for $185
5ohm impedance
sensitivity 87 db
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0p_sh0tta »</TD></TR><TR><TD CLASS="quote">What the hell do you listen to that has information below 20 hz? Or even down to 20 hz?</TD></TR></TABLE>
Planet Krypton - IASCA SQ CD - Track 5 - 18Hz notes from a tympani
Sorry, I had to
Back on topic....there are SQ guys who use those Focal Subs for SQ systems. Theres an E46 with 4 up front, and a Lincoln LS with a pair (one in each door) for SQ. I would not use that driver or a 6W0 for midbass - they are designed as subs. I would also keep from using a mono midbass...that should be kept stereo...
Sorry, I had to
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22akrd »</TD></TR><TR><TD CLASS="quote">what would you suggest to run a focal 5ws for midbass?</TD></TR></TABLE>
see my post above...don't use them for midbass....
Not only are they not suited for sealed, they also can't go free-air (you want a QTS of at least 0.5 and up around 0.6 or higher is better - that focal is down at 0.36). That leaves you with a 5+ liter ported box...not very big, but something to keep in mind.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22akrd »</TD></TR><TR><TD CLASS="quote">rcurley55.. you ahve pm. help a brotha out </TD></TR></TABLE>
I returned it...
I returned it...
A friend of mine put a 6W04 into the factory enclosure in his M coupe. he blended in a proper mdf spacer on to it and lined it with dynamat extreme. no idea what it's tuned at but it has a lot of output and sounds alright for a sub just stuffed into the factory ported enclosure.
We did a 01 porsche 911 c4 with 3 6w08s in sealed behind the seat and under the glass, with the baffle on a 45 degree angle towards the floor. it sounded pretty sweet.
I've also heard two 6w04s in a ported box that hit 133.4 dB off real music with 100w rms per sub.
6" sub, JL audio.
6" sub, JL audio.
pinoyboy204
Audio / Security / Video
Dec 29, 2002 12:05 AM
