Help with how to shave side moldings
Im trying to get some advice from some people that have shaved there side moldings on there EF's. Im kinda tripped up on how to make it look smooth and make all the lines flow together, since the bottom sticks out more the the top of where the molding was removed
. Any help would be great.
if you plan on shaving the molding to be flush with your door, then you don't have to worry about the holes. just make sure you spend more time smoothing out the fiberglass before applying the bondo...fiberglass is key
mrmonk
Feb 20, 2004 10:47 AM
speed_racer012
Apr 19, 2003 05:08 PM
Ill give it a try with the fiberglass and see how that works for me then.
