93 Cluster Lights (and tail lights) out...Is it the Dimmer Relay?
Old Sep 1, 2003 | 06:30 PM
Rwecked's Avatar
Default 93 Cluster Lights (and tail lights) out...Is it the Dimmer Relay?
That pretty much sums it up. On the Integra it was the Interior Lights fuse under the hood, but on the Prelude all I see is a Dimmer Relay. Is this the part I should be replacing? Search came up empty and I just need to know before I hit the dealer. Thanks Guys & Gals!
Old Sep 2, 2003 | 05:21 AM
CHK4TIX's Avatar
Default Re: 93 Cluster Lights (and tail lights) out...Is it the Dimmer Relay? (Rwecked)
i have an extra dimmer relay if you think that would help
Old Sep 2, 2003 | 10:30 AM
stock92prelude's Avatar
If you have aftermarket lights in the front it may be grounding itself improperly. My friend had this problem and we kept replacing the fuses.(nissan car). We ended up having a shopp look at it and they found a stripped wire.
Old Sep 2, 2003 | 04:46 PM
prelude1897's Avatar
Have you checked the fuses under the hood and inside the car?
Old Sep 2, 2003 | 04:57 PM
skunk2lude01's Avatar
I had exact same problem in my lude, it was due to idiot *** friend wiring my cd player incorrectly.
CooBreeze
Jan 26, 2021 10:22 PM
ltec
Feb 13, 2013 05:17 PM
RA100923
Oct 4, 2012 09:27 PM
alfaaay
Nov 10, 2009 05:30 PM
