Those of you who have replaced bushing in the rear LCA's.
Old Sep 1, 2003 | 05:37 PM
poison's Avatar
Default Those of you who have replaced bushing in the rear LCA's.
I'm in the process of installing 5 lug on an EG, one of the friggin LCA bolts on the drums broke on me, and I have an extra LCA with me, but the strut bushing is all ripped out.
What I did is went to Honda and purchased another bushing from 'em, however, the damn bushing won't come out. I've talked with friends as far as having the metal ring that goes around the bushing pressed out, and the new bushing pressed in, I was just wondering for those of you who have "been there done that" had to say.
What's your advice?
If pictures will explain better, I'll definitely jump on some.
TIA.
Old Sep 1, 2003 | 05:59 PM
aw1234dude's Avatar
Default Re: Those of you who have replaced bushing in the rear LCA's. (poison)
Im not too sure what the metal ring looks like but if its straight through and atleast half an inch in diameter you can probably take a hacksaw to it. Just cut a slit in the metal ring and it should come loose.
Old Sep 1, 2003 | 06:02 PM
Eee Pee's Avatar
Default Re: Those of you who have replaced bushing in the rear LCA's. (aw1234dude)
Without a press it's a pain.
Like he said above, remove the rubber part so it's just the metal outside shell remaining.
Draw a hacksaw across it until the outer shell is split.
Use a screwdriver to bend and pry and drive out the outer shell.
Old Sep 1, 2003 | 06:03 PM
rolow's Avatar
I used a torch on my f150 it take some time but works if you don't have access to a press.
I used a press on my civic
Old Sep 1, 2003 | 06:07 PM
poison's Avatar
Default Re: Those of you who have replaced bushing in the rear LCA's. (Eee Pee)
Thanks guys. That ring is a pain in the ***.
With that press, what did you guys do to get that ring in there? Seems like it's a very tight fit. Just hope to not screw up the bushing.
I'll get some pics up to better explain.
Old Sep 1, 2003 | 06:12 PM
VX's Avatar
VX
Maybe this will help: http://home.socal.rr.com/civic...x.htm
Old Sep 1, 2003 | 06:13 PM
Eee Pee's Avatar
Make sure everything is perpendicular.
It's task 9 tons can take care of no sweat.
Old Sep 1, 2003 | 06:17 PM
poison's Avatar
Default Re: Those of you who have replaced bushing in the rear LCA's. (VX)
Thanks for the help guys.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VX &raquo;</TD></TR><TR><TD CLASS="quote">Maybe this will help: http://home.socal.rr.com/civic...x.htm</TD></TR></TABLE>
Thanks a lot bro!
91GEDHATCH
May 18, 2011 06:23 AM
My JDM EJ8
Jul 9, 2008 06:05 AM
kixcrx
30
Dec 21, 2006 01:41 PM
broketuner-Sol_Si
Suspension & Brakes
Apr 25, 2006 08:04 AM
a1k0n
Jun 6, 2003 02:18 PM
