D series block
Old Sep 1, 2003 | 05:37 PM
pirocrxracer's Avatar
Default D series block
The other day i was driving back to school and i blew my 90 model D16a6 motor. Everything thing is ok except for the block and i was told that i could take the crank and piston out of my si motor and put it in the block of a hf. They said that the si and hf are the same block just that the si has a shorter stroke that gives it more dicplacment. If anyone knows anything about this please let me know. thanx a lot.
Old Sep 1, 2003 | 05:41 PM
phatrick2332's Avatar
the si motor has a longer stroke..thats what makes it a 1.6. And your going to have to find a 1.6 block because the main bearing journals are smaller on all the 1.5 liter d-series blocks.. I just tried to put the a6 crank into a d15b2 and the journals are way to small in that block but maybe the d15b6 that the HF has, has the same journals as the a6 block..im not certain on that..
Old Sep 1, 2003 | 07:22 PM
USDM 4G VTEC's Avatar
Default Re: D series block (pirocrxracer)
how u blew the motor????
trow a rod?
if u did u broke a rod, more likely ur crank has some sort of streess and damage into it
Old Sep 1, 2003 | 07:31 PM
Timmah!!'s Avatar
Default Re: D series block (USDM 4G VTEC)
Dont bother doing a rebuild on a d series unless you are going to build the motor. I would jsut get another d16a6 for like 100 dollars from a fellow HTer. Or do a better swap. It will be MUCH cheaper then rebuiling the motor.
Just my lousy .02
Old Sep 1, 2003 | 10:20 PM
89dxhunchback's Avatar
Default Re: D series block (azroth)
Just get any D you want. If your an all motor kinda guy, get a Y8. If your car is just a beater to get you to work find a DX/STD/Si block or motor. If you like turbo power than anything will work ( A6/Z6/Y8 ).
replace the motor is cheaper than rebuilding a D.
acro1010
Sep 15, 2010 02:57 PM
JDM Lyfestyle
May 4, 2009 08:30 PM
my_little_beast
Dec 19, 2004 07:10 AM
Kirt Porter
Nov 12, 2004 11:13 PM
