Lookin for b20 info/ tried search
Old Sep 1, 2003 | 04:09 PM
4DRPIMPIN's Avatar
Default Lookin for b20 info/ tried search
I need a complete list from start to finish to put a b20
in a eg cx. I need to know what exact parts I need,
i.e. ls intake manifold etc,harnesses, what axles (b series?)
what ecu will plug right in, what extra wires do I have to
run, what is the best tranny (non turbo,non vtec, stock
motor). what bracket for the ac does everyone use
(hasport?). any info would be appreciated, and any
problems encountered will help to........thank you in advance
Old Sep 1, 2003 | 04:16 PM
eg_type_r93's Avatar
its like any other b series swap dont let the b20 fool you just cant use the b20 tranny and intake manifold and thats it ........... do a search
Old Sep 1, 2003 | 04:29 PM
Dancing is Forbidden's Avatar
Default Re: Lookin for b20 info/ tried search (4DRPIMPIN)
in a eg cx. I need to know what exact parts I need, i.e. ls intake manifold Yes, use an LS or Skunk 2 mani for an ls
etc,harnessesuse your stock harness but modify for 4 wire 02
, what axles (b series?)Yes ANY 94+ B series axle parts will work
what ecu will plug right in best bet is to convert the dist to OBD-1 as well as injectors and use either a p75 or pr4 ecu, they plug right in,
what extra wires do I have to runas stated earlier run the 4 wires for o2 and, convert to OBD-1 ]your injectors and dist.,
motor) b16a tranny will roll any stock b series up to 100 just cause of the torque up (maybe not an RRRRRR).
(hasport?)del sol vtec will work
problems encountered will help to........thank you in advance It should 0wn!!!!!
Old Sep 1, 2003 | 05:34 PM
Strem's Avatar
Default Re: Lookin for b20 info/ tried search (EF9_SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF9_SiR &raquo;</TD></TR><TR><TD CLASS="quote"> I need a complete list from start to finish to put a b20
All this sounds cool, the only thing I did different was, I used the Distributor that came with my B20 long block. Just match up the color code coming out of the dist. to the colors on the wiring harness. The plugs will not fit together so I used soldier and heat shrink, runs like a champ.
I'm also using an LS tranny. My plans include a turbo so I went with the longer gear ratio set up. If you're going NA I'd go with a b16,b18c or whatever just go with the shorter gear ratios.hmm any other questions I'd be happy to assist
Old Sep 3, 2003 | 11:33 AM
4DRPIMPIN's Avatar
How do I convert to a 4 wire o2 sensor?
Old Sep 3, 2003 | 11:34 AM
4DRPIMPIN's Avatar
Strem, what a ecu are you using? thankx
Old Sep 3, 2003 | 11:35 AM
4DRPIMPIN's Avatar
What about shift linkage? sorry for so many questions, just trying to make sure i have everything covered..
Old Sep 3, 2003 | 12:06 PM
92SiHatchie's Avatar
Default Re: (4DRPIMPIN)
i used all gsr parts in my b20,except ls mani,flywheel,and ecu.use your stock wiring harness.you can use a pr4 or p75 ecu.peace!
Old Sep 3, 2003 | 12:13 PM
B20BHatch's Avatar
you also need to Re CC the head
Old Sep 3, 2003 | 07:20 PM
Rukusmasta2's Avatar
Default Re: Lookin for b20 info/ tried search (B20BHatch)
wut kind of times are u guyz gettin with this motor in an eg
Old Sep 3, 2003 | 07:28 PM
Strem's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4DRPIMPIN &raquo;</TD></TR><TR><TD CLASS="quote">Strem, what a ecu are you using? thankx
I'm using the PR4
I'm going to install a chip soon to richen the A/F mixture and increase RPM to 8400.
different cams and turbo in my future.
Old Sep 3, 2003 | 07:33 PM
Strem's Avatar
Default Re: Lookin for b20 info/ tried search (Rukusmasta2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rukusmasta2 &raquo;</TD></TR><TR><TD CLASS="quote">wut kind of times are u guyz gettin with this motor in an eg</TD></TR></TABLE>
My engine right now as it sits has 100 miles on it. It was a fresh rebuild with GE sleeves and is low compression. So I don't have any numbers yet. But it really feels strong. Now when I'm driving on the highway all you got to do is just keep it in fifth and give it alittle gas and squirt in and out of traffic. Torque is good! Can't wait for next summer....turbo time!
Old Sep 6, 2003 | 05:40 AM
4DRPIMPIN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20BHatch &raquo;</TD></TR><TR><TD CLASS="quote">you also need to Re CC the head </TD></TR></TABLE>re cc the head???? please advise...
Old Sep 6, 2003 | 11:31 AM
4DRPIMPIN's Avatar
any pics of these swaps?
Nameless RB26
14
Jul 29, 2009 06:10 PM
allricedout
10
Mar 4, 2007 03:57 PM
white4doorsi
Feb 28, 2007 08:23 AM
4drRacer
Sep 3, 2002 06:07 PM
