try to start car but got a bunch of clicks!! wtf???
Old Sep 1, 2003 | 12:35 PM
ILOVEGIRLS's Avatar
Default try to start car but got a bunch of clicks!! wtf???
why is this? it will start when i bump start it though..
Old Sep 1, 2003 | 12:46 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Default Re: try to start car but got a bunch of clicks!! wtf??? (ILOVEGIRLS)
Either the battery or the starter is dead. I'd check the battery first.
Old Sep 1, 2003 | 01:03 PM
thaiphob's Avatar
Nikon!!!
Default Re: try to start car but got a bunch of clicks!! wtf??? (Gee3)
if its clicking your batt should be fine. sounds like the starter to me.
Old Sep 1, 2003 | 01:14 PM
ILOVEGIRLS's Avatar
Default Re: try to start car but got a bunch of clicks!! wtf??? (thaiphob)
battery is new. how can u check if its the starter?
Old Sep 1, 2003 | 01:17 PM
thaiphob's Avatar
Nikon!!!
you can goto autozone and get it checked for free.
Old Sep 1, 2003 | 01:40 PM
ILOVEGIRLS's Avatar
do u need to take it out?
Old Sep 1, 2003 | 02:06 PM
speedymon's Avatar
Try to pop start the car. If you're successful then its the starter
Old Sep 1, 2003 | 02:14 PM
LSTEG96's Avatar
Default Re: try to start car but got a bunch of clicks!! wtf??? (speedymon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedymon &raquo;</TD></TR><TR><TD CLASS="quote">Try to pop start the car. If you're successful then its the starter</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ILOVEGIRLS &raquo;</TD></TR><TR><TD CLASS="quote">why is this? it will start when i bump start it though..</TD></TR></TABLE>
Old Sep 1, 2003 | 02:16 PM
SIK IN DA HED's Avatar
New User
Default Re: try to start car but got a bunch of clicks!! wtf??? (LSTEG96)
i think your starter is faulty. it shouldnt be your battery. if its constantly clicking and your lights are flickering... and it sounds like your car is dying... its your battery. maybe it could be your alternator.
Old Sep 1, 2003 | 03:03 PM
Al Bundy's Avatar
put water in your battery
Old Sep 1, 2003 | 10:11 PM
92AztecGsr's Avatar
I had that problem with my ls I found that it was the negative battery cable was loose.
Old Sep 2, 2003 | 05:17 AM
JwM's Avatar
JwM
Default Re: (954doorgsr)
Yeah, I had that happen once too... Check all your connections before you pull your starter out... You may get lucky.... I never realized how finicky the electrical system is prior to that...
Old Sep 2, 2003 | 06:54 AM
ILOVEGIRLS's Avatar
Default Re: (MayonakaNinja)
ill do that tonight.
Old Sep 2, 2003 | 09:27 AM
Teg4e's Avatar
i once killed my battery playing the stereo w/o the engine on. All I heard were clicks, like you mentioned. Try jump starting it.... worked for me.
Old Sep 2, 2003 | 03:59 PM
ILOVEGIRLS's Avatar
Default Re: (Teg4e)
i can bump start it.
Old Sep 2, 2003 | 04:07 PM
B U N M A N G O's Avatar
Default Re: (ILOVEGIRLS)
try hitting your starter w/ a broomstick or something
Old Sep 2, 2003 | 06:45 PM
ILOVEGIRLS's Avatar
Default Re: (B U N M A N G O)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B U N M A N G O &raquo;</TD></TR><TR><TD CLASS="quote">try hitting your starter w/ a broomstick or something </TD></TR></TABLE>
did that no love. how much are starters anyway?
Old Sep 2, 2003 | 06:48 PM
IntEGNYC's Avatar
check the distributor and wiring as well.
Old Sep 5, 2003 | 12:03 AM
ILOVEGIRLS's Avatar
Default Re: (IntEGNYC)
its the starter!! does anyone have a pre OBD b16 starter?
pgpunkguy
Jan 22, 2008 11:29 AM
pepper
Sep 21, 2007 07:27 PM
k_lude
Feb 6, 2007 12:01 PM
eg686
Aug 22, 2005 10:16 PM
5lugSlug
Jul 13, 2005 06:41 AM
