confirm/corect what i was told about bad struts...
Totally wrong....if you push down hard and let up, good struts will rebound once and maybe a little shake....bad struts will allow the car to keep bouncing. There is no way a car will rebound "slowly" as you say, because the spring pops it right back up....
You can also have a seized strut where it wont bounce at all, but what Ef ***** sid is true, it will bounce like a caddy.
uhh the springs and struts are not on the car, so yes when i push down on them they slowely come back up, so whats up with that
