JDM Foglight switch question
first of all, ive searched and couldnt come up with any answers...
i just wanted to know
what options do we have when mounting the JDM foglight switch on ITR's? is the dimmer the only place? also..is it necessary to have anything other than the actual foglight switch? or is the foglight switch all u need?
any info appreciated. thanks alot in advance.
if you are telling us you did not find threads about this already, you are telling us that a monkey with 1 arm and 1 leg with half a brain could search better than you
go back, search more young grasshopper!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Type-R »</TD></TR><TR><TD CLASS="quote">first of all, ive searched and couldnt come up with any answers...
what options do we have when mounting the JDM foglight switch on ITR's? is the dimmer the only place?</TD></TR></TABLE>
-You could replace the dimmer with it, but most of us put it at the blank hole on the other side of the steering wheel.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Type-R »</TD></TR><TR><TD CLASS="quote">also..is it necessary to have anything other than the actual foglight switch? or is the foglight switch all u need?
any info appreciated. thanks alot in advance.</TD></TR></TABLE>
-you need foglights, wiring, relay.
