OBD0-OBD1 GURU's please help EF
Car was running obd0. setup is a d15 with a z6 head. obd 0 injectors with a resistor box. p28 ecu and an obd1 dist and conversion harness. i know the harness is good because i sent it to get fixed. the dist and ecu i am not so sure about. here is the problem:
when i installed all the obd1 stuff car would not start and i had a code 22 (vtec oil presure). i though ok lets switch the white wires. switched em but had no luck starting. but the code 22 went away. when car did not start i kept switchin the wires and reseting the ECU. the code 22 only came on when the wires were switched wrong (i am assuming that the code means the wires were wrong).
car stil would not start and was getting no spark (i checked with a timing light) but i smelled fuel. took off cap and rotor and cleaned everything throughly still no start and no codes and no spark. someone please help or ill be riding the skateboard to school tomorow.
grounds are good. what wires do i check? i need some colors. car was running fine when it was obd0 just had a problem with the dist.
if you could tell me everything you're running you might be able to help me uout a bundle as i've got some issues of my own email me back at tomsweet1990@hotmail.com i'd love to hear about your setup
tgh22a
11
Apr 17, 2006 03:56 PM
spun Vtec
May 12, 2003 05:02 PM
