need help probs with reading ecu code.
i did a obd0-obd1 conversion on my hatch and i dont really know anything about reading codes from a p28. the car cranks over but dosnt start i havnt checked for spark but im getting a code of one short blink followed by 4 regular blinks so whatever code that is it beats the heck out of me.
also is there a resistor box at all on an obd1 car? the directions i got with my conversion harness said that i didnt need one but i need to know what to do with the wires going out of the injector's i know the red/black wires (obd0 car)(yellow/black on obd1 car) go to the 7wire harness but what about the other wires comming from the injector's? do they just go like they already do stock (89 civic)
i guess my question is what wires are needed going into that 7wire capped plug? and what is done with the other injector wires for each wire?
sorry if thats confusing
-larry
-larry
1 Post
Re: need help probs with reading ecu code. (spun Vtec)
Is there a bit of a pause between the 1 long and 4 short or is it one right after the other?
1 long=10
1 short= 1
If it's 1 long then 4 short right after then its one code
so 1 long and 4 short would=14 which is: IAC Valve (Idle Air Control) defective circuit or unplugged / defective sensor
1 long=10
1 short= 1
1 Post
Re: need help probs with reading ecu code. (CIVICVTI2)
If it's 1 long then a pause then 4 short then it would be 2 different codes.
it would be code 10: IAT Sensor (Intake Air Temperature) defective circuit or unplugged / defective sensor
and code 4 CKP Sensor (Crankshaft Position Sensor) defective circuit or unplugged / defective sensor
Kinda confused on the rest but maybe someone else can help.
my bad it is 4 then a short one then a pause then same thing
could be o2 but you would think that would come on after the car was running not cranking over
hatch_kidb18b1
42
05-11-2010 02:33 PM
spun Vtec
05-12-2003 12:13 PM
