flywheels????
Old Aug 31, 2003 | 04:37 PM
Audi RS4's Avatar
Lover
Default flywheels????
is there anyone that is using an ITR flywheel on a B16? and if so share your thoughts and expeirences about ITR flywheel vs B16 flywheel vs aftermarket flywheel (e.g Fidanza, Exedy, Toda, Spoon etc....).
thanks
Old Aug 31, 2003 | 05:15 PM
SimbaDogg's Avatar
Default Re: flywheels???? (AK1200)
how much weight can be shaved off a stock b16 flywheel? i hear they weigh in @ about 17 lbs...anyone have any figures?
Old Aug 31, 2003 | 05:33 PM
eg6ajk's Avatar
i run stock 18lbs (b16a/b18c1/b17a/b18b flywheel), as well as ITR (15.5lbs) as well as shaved stock b16a to 12lbs then ran JUN/Cusco/Toda (8.5lbs) units.
basically I find the shaved 12lbs as best overall perfrmance and overall feeling in the car. the lighter JUN/Cusco units feel very well but I find it slightly too light, for the torquless b16a....
look into the ACT XACT flywheel they make it in 8 and 12lbs cost around $225shipped or so.
Old Aug 31, 2003 | 05:41 PM
Audi RS4's Avatar
Lover
Default Re: flywheels???? (eg6ajk)
how did you go about "shaving" the flywheel? what's the process?
Old Aug 31, 2003 | 06:18 PM
eg6ajk's Avatar
take it to a machine shop let them take the weight off /machine off the material. then get it balanced and resurfaced. about $100-150 price tag in which case it might be more cost effective and more reliable to get a XACT.
my shaved to the extreme ITR flywheel
another done by honda only shop. looks alot better then above and properly balanced as well . above flywheel might develop or loose the ring gear after a while.
TODA chromoly
Old Aug 31, 2003 | 08:11 PM
NA gs-R 05 C
Guest
Posts: n/a
if you're gonna replace your fly, might as well go with an aftermarket fly, and for street use, somewhere between the line of 11-13 lbs is perfect (but that's imo ofcourse).
chadmasterc
Oct 12, 2005 04:17 PM
fastitr01
Aug 23, 2004 03:01 PM
dfoxengr
Feb 16, 2004 10:10 AM
DA666
Dec 27, 2001 07:37 AM
Rodney
Aug 16, 2001 05:58 PM
