too rich in only one cylinder, help
im running too rich in only one cylinder, the rest is fine when i look at the spark plugs. the cylinder is number 4, what can cause this? what can i look into?
Take the fuel rail out and make sure the injectors stay in the rail. Then turn the key on, the fuel pump will turn on to prime the system and will pressurize the rail/injectors. If the injector leaks gas, it should be replaced.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Runnerdown »</TD></TR><TR><TD CLASS="quote">Take the fuel rail out and make sure the injectors stay in the rail. Then turn the key on, the fuel pump will turn on to prime the system and will pressurize the rail/injectors. If the injector leaks gas, it should be replaced.</TD></TR></TABLE>
Don't the injectors come out when you take the fuel rail out.
I heard some people use a battery and hook up to the injector for it to open then use presurised air to clean out the internal. I want to clean my injectors also but I'm not sure if this is safe.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blah13 »</TD></TR><TR><TD CLASS="quote">You can either have it rebuilt or get a new one. Personally I'd get them all balanced or replace them all at the same time.</TD></TR></TABLE>
The o-rings where the injector goes into the rail will usually hold them in. Sometimes though the grommet that the injectors seats into will want to hold it. A long as you take them out carefully you should be ok. I have done this plenty of times.
blu3fan
Nov 16, 2012 05:05 PM
