My VTEC x-over point w/ ITR cams
My mods are in my sig. I am getting ITR cams installed on friday. along with STR cam gears. I was wondering what I should put the vtec crossver at? I am going to the dyno but I wanted to just change it so Im not kicking in at 4600 like I have in my VAFC right now. I don't need an exact match obviously because its tough to say over the internet what my car should crossover at (thats for the dyno). But around what should I place it around. I've had a few guys tell me about 5000rpms or so. Just wanted some opinions from you guys. Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso »</TD></TR><TR><TD CLASS="quote">If your going on a dyno soon then why ask?</TD></TR></TABLE>
...every car is diff...with one ctr cam i would have benefited with a 6k rpm crossover...but my friend would have benefited more from a 5500 x over
u really just want the cross over to be as smooth as possible, some cross over dips ive seen are pretty bad. But i think something around 49-52 would work well !!
it will aslo depend on the person doing the tunning!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 »</TD></TR><TR><TD CLASS="quote">my vtec used to be at 5100rpm.. although you can make power with lower vtec point, around 5100-5300rpm should give smooth transition and midrange gains..</TD></TR></TABLE>
Smoothest crossover before and after dyno tuning was 4900 rpm in my old '94 GS-R.... R cams, AEM gears, VAFC, B&M FPR.
135k mile GS-R
135k mile GS-R
friends gsr with ctr cams runs a 4600 vtec x-over.
i have a 4700 x-over with ctr cams.
but we both use stock gsr manifolds...so your x-over might be totally different than ours
I have CTR cams in my GSR (1994) and just through the butt dyno , figured 5400rpm seems to be the best position, but it also depends on what mods have been done, i only have i/h/e and test pipe, i set it at 5600rpm and found the car bogged considerably just below that so moved it to 5400rpm and its a much smoother transition with no bogging. I hope to get it on a dyno soon and have it set up properly (field SFC)
92TypeR
27
Oct 12, 2005 02:00 AM
dLo GSR-stolen-now-WRX
Apr 14, 2003 09:37 AM
