Bolt Rounded. How do I get the seats out?
Old Aug 31, 2003 | 12:33 PM
lildrgn2.0's Avatar
New User
Default Bolt Rounded. How do I get the seats out?
http://www.import-enthusiasts.com/stuff/boltx3.jpg
Ok. this is the driver side. The bolt is starting to round off, and as most of you know there is very little room to work back there.
So how do I break the bolt loose?
Any one else ever have a problem like this?
96 Prelude Vtec
Old Aug 31, 2003 | 12:45 PM
Prelude Vtec 23's Avatar
Default Re: Bolt Rounded. How do I get the seats out? (Lildrgn)
You can try getting that new craftsman tool they have for removing rounded bolts. People that have used it says it works perfectly.
Old Aug 31, 2003 | 12:47 PM
4bidden's Avatar
Default Re: Bolt Rounded. How do I get the seats out? (Prelude Vtec 23)
Yea, the Craftsman tool works wonders.
How in the world did you round it? Were you using a 12pt socket or something?
Old Aug 31, 2003 | 12:49 PM
lildrgn2.0's Avatar
New User
Default Re: Bolt Rounded. How do I get the seats out? (4bidden)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4bidden &raquo;</TD></TR><TR><TD CLASS="quote">Yea, the Craftsman tool works wonders.
How in the world did you round it? Were you using a 12pt socket or something?</TD></TR></TABLE>
yea
My other one is missing, so I used my cheap ones. The other one came out ok, but now I have one on the passenger and one on the driver that just wont come out. I even tried a cresent and it started rounding it.
Old Aug 31, 2003 | 02:46 PM
AndyD's Avatar
Yeah, my Craftsman set has helped me A LOT. It is worth the money
Old Aug 31, 2003 | 07:00 PM
HotWheelz's Avatar
Default Re: Bolt Rounded. How do I get the seats out? (AndyD)
vice grips!
ahahhaa... eh.. your probably using a 12point socket, use a true 6 point and you'll be ok..
Old Aug 31, 2003 | 07:12 PM
PetroGuyX's Avatar
i was gonna suggestion an adjustable wrench, but i don't know how much good that would do
Old Aug 31, 2003 | 07:48 PM
str8rcn's Avatar
Default Re: (PetroGuyX)
Whats this cool craftsman tool everyone is talking about?
Old Aug 31, 2003 | 09:17 PM
stock92prelude's Avatar
That is funny. Not that you can't get your seat out but that i have been fighting with my passenger side seat back left bolt for over a week now. My bolt has completely rounded off. I have tried everything from chisel and hammer to trying to beat a smaller socket on to the bolt. Nothing will give. I am just wondering though, can you move your seat around? I can rotate my seat and the bolt will move with it for the couple of inches i can move my seat. If i figure out how to get it off I will definetly let you know something!
Old Aug 31, 2003 | 10:15 PM
kotetu's Avatar
Default Re: Bolt Rounded. How do I get the seats out? (stock92prelude)
try a gator grip, that socket from the 'as seen on tv' stores.
It works pretty well and should adjust itself to fit what's left of your bolt.
Old Sep 1, 2003 | 01:06 AM
Chief Brody's Avatar
Do it right the first second time!
Community Builder
Active Streak: 30 Days
Default Re: Bolt Rounded. How do I get the seats out? (kotetu)
SAAAME problem on my lude. VICE GRIPS and a hammer... trust me it works
Old Sep 1, 2003 | 01:43 AM
4bidden's Avatar
Default Re: (str8rcn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by str8rcn &raquo;</TD></TR><TR><TD CLASS="quote">Whats this cool craftsman tool everyone is talking about?</TD></TR></TABLE>
http://www.sears.com/sr/crafts...Id=45
Old Sep 1, 2003 | 05:18 AM
GruvyTune's Avatar
New User
Default Re: (4bidden)
link did not work
Old Sep 1, 2003 | 09:29 AM
itr1235's Avatar
Default Re: (GruvyTune)
try cutting a slot i the bolt and use a flat head screwdriver attached to a ratchet. if that does work weld another bolt and go from there
Old Sep 1, 2003 | 09:32 AM
SKDRCR's Avatar
yeah i pulled a chester move when i was putting
my seat back in, all the change that fell out of my pocket over time
clogged up my recliner an it wouldn't move, so i took the seat out
turned it upside down, shook it vigorusly, and voila recliner worked
but when i put it back in i used an air wrench and crossthreaded it
so i fixed it with a die grinder set
Old Sep 1, 2003 | 08:28 PM
ironcheftony's Avatar
metwrench!
Old Sep 2, 2003 | 02:05 PM
U-Tprelude's Avatar
Some tool manufacturers make a tool called an "Impact wrench"
similar to the tool that is used by pit crews and body shops, except theirs is a drill set-up. The impact wrench is a large-bodied driver with changeable heads (ie: sockets, philips, flat, etc.) that is placed on the nut and then hammered. Everytime it's hammered the wrench turns slightly, slowly working the bolt loose without stripping it.
works wonders.
Old Sep 2, 2003 | 09:26 PM
laughinxxx's Avatar
New User
Default Re: Bolt Rounded. How do I get the seats out? (00prelude-type-s)
Just get a bolt extractor.
drill a hole into the bolt, hammer in the extractor, and unscrew the bitch. If you can't find the part locally, you can get it from http://www.eppys.com. A set of 1/4"-1/2" extractors is $13.44. The part number is LIS 62900. Ask for keith. He is their rep on Preludeonline.com. phone 800-441-6117
Old Sep 3, 2003 | 05:21 AM
rjr162's Avatar
Default Re: Bolt Rounded. How do I get the seats out? (laughinxxx)
you should be fine if you go with a 6 point. 12 points round them off because they are 6 sided bolts, but don't round them enough that you can't get a 6 point on and get the bolt out. If it's really f'ing stuck get a "manual" impact driver... you can get them at sears. Works just like an impact gun, but you hold it in one hand and hit the top using your other hand with a hammer. Puts some good torque on the bizatch to atleast brake it loose for you
Old Sep 3, 2003 | 02:53 PM
LudeyKrus's Avatar
Go to Sears and buy a set of Craftsman Bolt-Outs....they work AWESOME! You just gotta make sure they get started good. I used mine when I stripped off a head stud...
Old Sep 3, 2003 | 09:02 PM
machinehead's Avatar
cut the nut with a dremel. you'll need a new nut though.
Old Sep 3, 2003 | 11:11 PM
flip1199's Avatar
Default Re: (machinehead)
did u try a box end wrinch??
Old Sep 4, 2003 | 01:04 AM
93preludes's Avatar
Default Re: (flip1199)
the craftsman tool is your best bet we removed some stripped lugnuts.. its worth every penny.. go get it and save yourself the headache!
The tool in case you didnt know is basically a set of sockets that work like a reverse drillbit its threaded opposite of a drillbit so it can grab what your trying to remove... its craftsman, go to sears they'll know what you mean. good luck
Modified by 93preludes at 4:00 AM 9/4/2003
Old Sep 8, 2003 | 08:34 AM
i finally got that bolt out the other day. My friend and i used vice grips and a set of pliers(or however it is spelled). We used the pliers to squeeze the vice grips around the rounded bolt and turned the bolt that way. took a few minutes but now my interior is changed out so it was worth it!
DC4GB
Oct 12, 2006 10:25 PM
civicEXtreme
Suspension & Brakes
Feb 22, 2006 02:36 PM
Layziebtnh055
May 14, 2004 06:42 AM
216.226.142.95:27016
Jun 8, 2003 11:42 PM
Mikey
Apr 25, 2003 08:47 PM
