Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
What does PAX time mean?
Old Aug 31, 2003 | 09:38 AM
MrIllegalX's Avatar
Default What does PAX time mean?
In auto-x, what does PAX mean?
Old Aug 31, 2003 | 09:49 AM
.RJ's Avatar
.RJ
Default Re: What does PAX time mean? (MrIllegalX)
Its a correctoin factor applied to your time based on what class you are running in intended to give you an idea of how you stack up in competition against other classes. However at a local level this system is flawed because PAX is based on nat'l tour/national champ events, and inherently assumes cars prepped to the limit of the rule in that class.
Old Aug 31, 2003 | 09:56 AM
1GreyTeg's Avatar
Default Re: What does PAX time mean? (.RJ)
Here ya go read this;
http://www.azsolo2.com/reference/usingpax.htm
I used to have links to calculators but they seem to be defunct.
Old Aug 31, 2003 | 12:15 PM
MrIllegalX's Avatar
ok, thanks for the explanation. So when they have your "time rank" and "PAX rank", the PAX rank is if you were in the same class and the cars were equal?
Old Sep 2, 2003 | 09:03 PM
MrIllegalX's Avatar
bump. still wanna know
Old Sep 2, 2003 | 09:14 PM
Tyson's Avatar
Default Re: (MrIllegalX)
more or less, yes. its an equalizer to compare times between classes of different levels of performance.
Old Sep 3, 2003 | 07:47 AM
ZUL8R's Avatar
Default Re: (Tyson)
gotta love G-stock
STS has a great pax considering you can do so much..
Old Sep 3, 2003 | 09:35 AM
00R101's Avatar
Default Re: (ZUL8R)
PAX = Professional Autocross indeX
It was invented when ProSolo started as a means of comparing cars in different classes.
Old Sep 3, 2003 | 09:39 AM
krshultz's Avatar
"Time rank" sounds like raw time, before they've applied the PAX index to it. PAX rank is just that...the order in which everyone finished after indexing the times wiht the PAX index.
RacerZook
Oct 15, 2003 12:30 PM
JSTOCK
Aug 1, 2002 03:50 AM
solo-x
Jun 30, 2002 06:38 AM
slash00R
Sep 21, 2001 12:01 PM
