vafc issue
Old Aug 31, 2003 | 06:36 AM
92b16vx's Avatar
Default vafc issue
I've got a 93 EDM B16A2 in a 92 VX, being run by a P30. I/H/cat/E, and it doesn't throw CELs. Ok, here is the issue I hooked up my VAFC a couple weeks ago, and everyting is fine. I am running it flat till I can get to the dyno to maybe squeeze a few out of it. It is set for 6 in/6 out, 4 cylinder but nothing else, When I am driving around town I can take it to 7800rpms no problem, vtec is fine as indicated on the unit. HOWEVER, when I am on the autobahn, and I hit 5500rpm, and 100mph in 5th gear, my CEL comes on, and the vtec won't engage. Even if I stop at say a light, and then go, the vtec is still not engaging. The VTM wire is not connected. And it ONLY does this in 5th gear at 100mph when vtec hits. When I shut the car off and restart it, everything is back to normal. Anyone have any ideas?
Old Aug 31, 2003 | 09:17 AM
.xcalibur.'s Avatar
Default Re: vafc issue (92b16vx)
I have a similar problem. All my connections are perfect. But when i hit vtec in 4th or 5th past 80 or so, I get a CEL for code 22. No dents in my oil pan or what not. Anyone know anything..
Old Aug 31, 2003 | 10:00 AM
92b16vx's Avatar
I can't even pull the CEL, because it turns off when I restart the car.
Old Sep 1, 2003 | 01:41 AM
.xcalibur.'s Avatar
Default Re: (92b16vx)
The CEL may turn off..but its still stored in your ECU. Check it cause its still there.
Ntercooled
Dec 26, 2005 07:39 PM
Flux
Jun 7, 2004 08:50 PM
JDMlyfestyle
May 14, 2004 03:32 PM
vtecjb
Aug 7, 2003 11:10 AM
Visionist
Jul 26, 2003 07:24 AM
