vtec engaging in neutral!!!! please help!!
Old Jul 25, 2003 | 12:53 AM
Visionist's Avatar
Default vtec engaging in neutral!!!! please help!!
just had my vafc installed and now for some reason my vtec engages in neutral. is that normal? i thought that vtec doesnt engage unless you're in gear. let me know. thanks
Old Jul 25, 2003 | 12:59 AM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default Re: vtec engaging in neutral!!!! please help!! (jdmfantasy)
umm... the car doesn't really know if it's in gear or not as far as the RPMs go... so if the oil temp is right and you hit 4400... its on.
Old Jul 25, 2003 | 01:15 AM
IntEGNYC's Avatar
Default Re: vtec engaging in neutral!!!! please help!! (dLo GSR)
might be good for green light launches :D
for any problems, always look for the last change in teh system. In your case the vafc.
Old Jul 25, 2003 | 04:37 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dLo GSR &raquo;</TD></TR><TR><TD CLASS="quote">umm... the car doesn't really know if it's in gear or not...</TD></TR></TABLE>
But it has the VSS, so it knows whether the car is moving.
Old Jul 25, 2003 | 06:05 AM
Be3LiCiOuS's Avatar
thats odd!
Old Jul 25, 2003 | 06:37 AM
Xsi's Avatar
Xsi
Supposed to be 20KPH before it enguages isn't it? how do you know it's on, the VAFC telling you?
Old Jul 25, 2003 | 06:55 AM
BlackB18CTeg's Avatar
Default Re: (Xsi)
lol... dont worry about it.... vtec is not ACTUALLY engagin... the VAFC does NOT tell you when the vtec is engaging...
For example
YOu set the vtec at 5500 rpm, and the vtec controller reads 5500 rpm, it SHOULD be on, so it reports to you that it is on... I realized this when the RPM gauge on my vafc and my gauges were different. I was actually at 3000 RPM but my VAFC thought I was at 5500 RPM (had to reset it), so it thought my vtec was on... It just reports to you when ur vtec should come on... there is no real way for the VAFC to tell whether the car is moving or not... Dont worry about it.....
Old Jul 25, 2003 | 11:57 AM
Visionist's Avatar
Default Re: (BlackB18CTeg)
no no no .... haha the way i know is that i can hear my skunk2 stage one cams screaming like crazy!!!! so i know its at vtec and the Vto light on the vafc turns on ?? im asking if thats normal or not..... someone please rev your car up and see thanks!
Old Jul 25, 2003 | 12:01 PM
Visionist's Avatar
Default Re: (jdmfantasy)
what do i check in the VAFC???????? if that was the last thing i changed?
Old Jul 25, 2003 | 09:57 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmfantasy &raquo;</TD></TR><TR><TD CLASS="quote">what do i check in the VAFC???????? if that was the last thing i changed?</TD></TR></TABLE>
oh scratch my last idea. the VAFC doesn't know that the car is moving. like the previous guy said the VSS tells if its moving... and if im not mistaken you disconnect it when you install the VAFC. the VAFC will send the VTEC signal no matter what, so it'll engage all the time.
Old Jul 25, 2003 | 11:04 PM
B2FiNiTY's Avatar
With the VAFC, it alows vtec to be activated whenever. Doesn't matter if the car is cold or in neutral.
Old Jul 26, 2003 | 07:24 AM
Default Re: (dLo GSR)
oh scratch my last idea. the VAFC doesn't know that the car is moving. like the previous guy said the VSS tells if its moving... and if im not mistaken you disconnect it when you install the VAFC. the VAFC will send the VTEC signal no matter what, so it'll engage all the time.</TD></TR></TABLE>
yeah, u cut ur vss wire... HOWEVER, if you dont cut it (its optional), ur vtec will NOT engage unless moving.... I think that is correct.
dx2sicrx
Engine Management and Tuning
May 19, 2008 10:21 AM
Ntercooled
Dec 26, 2005 07:39 PM
bchomka
Oct 31, 2004 08:48 AM
B18Redline
May 27, 2003 10:07 AM
