No Reading from tach, speedo, digital mileage and temp*
Old Aug 31, 2003 | 12:35 AM
iam7head's Avatar
Default No Reading from tach, speedo, digital mileage and temp*
searched and check all fuse without luck
(driverside #6,9 and passengerside #10)
I got no reading from the tach, speedo and temp guage at all.
no cel light, etc.
what's works: back light, turn signal(inside and out), brake light(rear, third), VAFC still reading the rpms, all bulbs in the cluster is fine, dimmer works, "key in ign" light works and all other electronic in the car is fine except the parts i mention above.
*when the i turn the key to on and ign. the "battery" red warning light is one also* ???
anyone knows what's going on? I am lost here...thanks
(car=accord 2002 vtec f23a4)
(sorry for double post)
Old Aug 31, 2003 | 06:40 AM
MAX HARDCORE's Avatar
Default Re: No Reading from tach, speedo, digital mileage and temp* (iam7head)
hey, it's probly the wire in your harness from your ecu. rember how much of a pain in the *** it was to get to it.. when you come back from GODIZILLA land
i'll take care of it... BTW any luck finding the sir cluster?
Old Aug 31, 2003 | 10:07 AM
teamlegacy's Avatar
Default Re: No Reading from tach, speedo, digital mileage and temp* (MAX HARDCORE)
Probably a bad cluster.
Old Aug 31, 2003 | 01:32 PM
iam7head's Avatar
Default Re: No Reading from tach, speedo, digital mileage and temp* (teamlegacy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teamlegacy &raquo;</TD></TR><TR><TD CLASS="quote">Probably a bad cluster.</TD></TR></TABLE>
Um...can a short cause this? it should be fuse'd, right?
covered by honda?
Old Aug 31, 2003 | 01:44 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head &raquo;</TD></TR><TR><TD CLASS="quote">
covered by honda?</TD></TR></TABLE>
Should be covered if you have less than 36,000 miles on it.
Old Aug 31, 2003 | 01:54 PM
iam7head's Avatar
Default Re: No Reading from tach, speedo, digital mileage and temp* (Chiovnidca)
that's good news
Old Sep 1, 2003 | 07:35 AM
teamlegacy's Avatar
I'm pretty sure electrical problems are covered under warranty. As long as it's not your mistake in wiring say, a aftermarket head unit or subs.
Old Sep 1, 2003 | 02:31 PM
Beach Accord's Avatar
same happened to me. printed circuit board behind cluster was fried. covered under warranty.
projsectEF
12
Feb 10, 2007 08:13 PM
EH-3
17
Mar 15, 2006 03:23 PM
Orbby
Sep 20, 2004 09:01 PM
iam7head
Aug 31, 2003 01:33 PM
