Secondaries hooked up to vtec?
Old Aug 30, 2003 | 07:11 PM
Skyllz's Avatar
Default Secondaries hooked up to vtec?
I'll be running a chipped P28 until I get my skunk2 IM for my GSR.
Would there be a problem for the ECU to activate the secondaries and Vtec at the same time?
I am talking about power consumption here, I dont want to burn down anything in the ECU, at worst i'll hook up a relay of some sort.
Also, on the secondaries, there are 2 wires, 1 is ground, other one is positive from ECU? Or 1 is positive and other one is switched ground from ECU?
Thanks alot!!!
Old Aug 30, 2003 | 09:56 PM
PHiZ's Avatar
Default Re: Secondaries hooked up to vtec? (Skyllz)
Someone said the IAB differs between OBD1 and OBD2, might want to check that, one is postive activated, one is ground activated. Check a manual.
If you have a chipped P28, you can just have them locked open.
-PHiZ
Old Aug 31, 2003 | 11:33 AM
Lord Helmet's Avatar
Default Re: Secondaries hooked up to vtec? (PHiZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHiZ &raquo;</TD></TR><TR><TD CLASS="quote">Someone said the IAB differs between OBD1 and OBD2, might want to check that, one is postive activated, one is ground activated. Check a manual.
-PHiZ</TD></TR></TABLE>
obd1 is negative activated where obd2 is postive activated.
Old Aug 31, 2003 | 12:09 PM
Skyllz's Avatar
ok, so it means I ground the negative and can use my vtec output to activate the secondarties at the same time then...
Thanks alot!!!!
Old Sep 4, 2003 | 03:37 AM
.xcalibur.'s Avatar
Default Re: (Skyllz)
can you control the secondaries? i thought i was all vacuum control and not electrical.
Old Sep 4, 2003 | 08:27 AM
Skyllz's Avatar
You need an electrical signal to have the soleinoid open the secondaries with vaccum...
DOHC Kid
May 27, 2008 04:47 PM
mesonerz
Oct 1, 2007 08:23 PM
Mhollaek9
Jun 23, 2007 07:21 PM
viet_sensationz
May 26, 2007 06:33 PM
JDM DC2
Mar 12, 2002 07:32 PM
