prelude cv axles
After picking up my car from getting a new clutch installed. I notice that my steering wheel was really shaky. The shop said that the car will need an alinment. After getting home i notice that the fuild from the Cv axles had spread all over my inner fender!
So is this normal for axles to be damged and the alinments needed after clutch work??
Um no, Take that bish back! Now! They really screwed your car up because you shoulden't need an alignment to drop the tranny unless they diden't know what they were doing. It sounds like they forgot to put the nut on the outer CV joint or put the axles on the wrong sides somehow and it sounds like they cut your CV joint boot (fluid/grease). Seriously, take the car back now. You paid for someone to do the work correctly and they failed.
VDM_DC2
Suspension & Brakes
11
Oct 28, 2009 12:28 PM
