***B16 suspension/AXEL HELP PLEASE!***
ok i put a new trans in my crx b16a1, its an integra xsi tranny (rebult) and now when i go over 30mph my car shakes BAD it also does it when accelerating and turning to the right only , its not the cv joints , but i think i may be the passangers side axel! its def on the passengers side
what axels should i be using? right now i have 90-93 teg axels ,
you can also take the axel where it comes out of the tranny and move it up and down and around, it has alot of play in it, but i checked out my friends car and his does the same.
im very puzzled and need your guys help!!!!
thanks alot!!
thanks alot!!
ddi you take the dust shields out of the hubs when you did your swap? that could cause the axles to bind... aka the vibrations you are getting
i had to go with a teg 89 axle, but then again i believe i have an sir int. shaft, its longer than all the b18b's ive compared it with, and in the begining with the 90-91 teg axle it was binding causing a bad vibration, hasport says to use the axle from the 89 adn use the joints from the 91 because there stronger, I didnt because im to lazy to take apart a cv boot so about every 6k miles i just return them to az for my free set of replacement axles
Black4thgenEF
Mar 21, 2006 02:56 PM
crexer
27
Dec 22, 2004 10:39 PM
