What's the weight and size of 5th gen prelude rims?
I've got a set that I use as winter wheels ...
My ITR wheel + bridgestone re010 combo weighs about 34lbs.
my 5g prelude rim (base model, twisted 5 spoke thing) + Yoko H4 205/45 is about 39lbs.
they're awfully hefty.
Here is what I got when I weighed them at work:
Prelude rims w/ Bridgestone Potenza RE92 205/50/16 87V = 39lbs.
Type R rims w/ Bridgestone Potenza RE010 195/55/15 84V = 33lbs.
Everything above is correct and the offset is 55mm. Base and SH rims are the same dimensions and offset. They do allow you to run 225/40 tires with no rubbing problems.
