Runnin like poo
Old Aug 29, 2003 | 10:52 PM
sinatra's Avatar
Default Runnin like poo
Car: 1999 civic si
engine: b16a2
OK first of all, mods:
ecu: chipped p28
piggy back: vafc
cams: 98 itr
valves, springs, retainers: 98 itr
Block: stock b16a2 with new piston rings and rod bearings
intake: 98 itr
header: DC 4-2-1
cat: custom melted ( I think)
exhaust: Greddy SP
fuel: AEM fuel rail
Ok so here's the problem. Every now and then when I start the car it runs very rough. So rough that the thing won't really want to idle at all. The other day it wouldn't even start. It would crank but no go. Any ideas on where to go first? I was thinking of switching the ecu back out and using my stock ecu first off. Also every now and then it will puff blue smoke right after it is warmed up, when it is warm it doesn't puff smoke. I have been told that this is due to my possibly clogged cat or I have a leaky valve cover gasket. Any other ideas on what could be wrong? I really would like to get my car running well again. I will also post this in the all motor section.
Old Aug 30, 2003 | 02:24 AM
4DeepCivic's Avatar
Default Re: Runnin like poo (sinatra)
If you think it's the cat. Start it without one. Did you ever check you plugs? You might be running too rich. Start with those, coz it's easy. Do a process of elimination.
Old Aug 30, 2003 | 07:54 AM
sinatra's Avatar
Default Re: Runnin like poo (4DeepCivic)
thanx for the reply. checked plugs. Cream colored on all of em but still got oil on the #4 cyl one. Yeah lol I can't get my damn cat off cuz the bolts are too tight and i don't have an air compressor . Thanx for the responces keep em coming.
Old Aug 30, 2003 | 08:39 AM
quik1's Avatar
Was it caked in oil or just a little, you definitely have a problem with #4 do a compression and a leak down to determine if its valve seals or rings. I don't know if that would have anything to do with your start up problem though.
Old Aug 30, 2003 | 09:23 AM
sinatra's Avatar
Here are pics of the spark plugs. Left to right 4-1. See the oil on the threads?
Modified by sinatra at 10:54 AM 8/30/2003
Old Aug 30, 2003 | 10:14 AM
RCautoworks's Avatar
Looks like you could be running a little rich. Have you ever got the car tuned professionally ?
Old Aug 30, 2003 | 10:31 AM
sinatra's Avatar
Default Re: Runnin like poo (90blackcrx)
not yet. am tryin to ge the big things taken care of first before I go to a dyno tuner.
Old Aug 30, 2003 | 11:25 AM
quik1's Avatar
I think white is lean and black is rich so it looks like you might be running lead.
Old Aug 30, 2003 | 11:26 AM
sinatra's Avatar
Default Re: Runnin like poo (quik1)
Yes white is lean.
Old Aug 30, 2003 | 11:44 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sinatra &raquo;</TD></TR><TR><TD CLASS="quote">Yes white is lean.</TD></TR></TABLE>
Yeah sorry my fault. I suggest getting your car tuned to see if that helps.
Old Aug 30, 2003 | 11:56 AM
sinatra's Avatar
I am worried that we will be tearing the engine apart again. Either valve seals or piston rings are bad I think because of the blue smoke. I am not gonna tune until this thing stops smokin.
kuki
May 31, 2005 12:37 AM
sinatra
11
Sep 1, 2003 08:42 AM
95gsr
Mar 17, 2003 08:31 PM
TypeR 599
May 28, 2002 11:03 PM
rbf351
May 24, 2002 11:53 AM
