Car doesnt start?help needed
Old Aug 29, 2003 | 09:17 PM
honda89's Avatar
Default Car doesnt start?help needed
My older bro used my car for the weekend, he drops it off and leaves town be for i get home. I get in my car to go to the local car show and nothing!! I just push start it and all is running good. I drive around for 20 min. to let battery charge turn off car and now it wont start again! I got the battery checked and it is fine I have stong power to lighta and acc. but the the car wont start. Any ideas or solutions would be greatly appreciated.
Old Aug 29, 2003 | 09:28 PM
Stupid Ass's Avatar
Default Re: Car doesnt start?help needed (honda89)
First of all... beat your brothers ***!
Sounds like your alternator bro!
Also could be starter wire... this happened to me a while ago... the negative wire was loose and would sometimes make a connection and sometimes it wouldn't...
Old Aug 29, 2003 | 10:44 PM
sloweh3's Avatar
Yea man, it sounds like your alternator is shot. Just go to Advanced or Auto Zone and pick up a new one.
Old Aug 30, 2003 | 06:31 AM
honda89's Avatar
Default Re: Car doesnt start?help needed (H82BLGL)
I thought it was my alternator but like when I park it after driving and try to start it later no go but I cheched the battery and its charched? Would this be a starter problem?
Old Aug 30, 2003 | 06:44 AM
bagged89hatch's Avatar
yeah its a starter problem for sure
Old Aug 30, 2003 | 06:46 AM
Vinceg99's Avatar
Default Re: Car doesnt start?help needed (bagged89hatch)
So after you drive it around does it even attempt to start? Or do you just get nothing when you turn the key?
Old Aug 30, 2003 | 06:49 AM
check all the wires on it. there are two wires on the starter a thick one and a thin one the thick one should have 12 volta at all times and the thin one should have 12 volts when the key is in the crank position. if this all checks out then the next thing to try is have someone crank it while you tap on the starter with a hammer. hit it pretty hard and it might free u. sometimes the freeze up and need a little whack to get em goin. i would replace it then cause it had a dead spot in it and wil only lead to aggravation down the road. if you do not have 12 volts at the little wire when the key is in the crank position then i would check your clutch safety switch if it is manual trans and your neutral safety switch if its automatic. let me know how you make out
Old Aug 30, 2003 | 09:50 AM
honda89's Avatar
were is the clutch saftey switch located?
Old Aug 30, 2003 | 09:57 AM
RCautoworks's Avatar
Default Re: Car doesnt start?help needed (Vinceg99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vinceg99 &raquo;</TD></TR><TR><TD CLASS="quote">So after you drive it around does it even attempt to start? Or do you just get nothing when you turn the key? </TD></TR></TABLE>
Old Aug 30, 2003 | 10:53 AM
honda89's Avatar
Default Re: Car doesnt start?help needed (90blackcrx)
It does nothing, no click, zipo
All is well after givinng the starter a heafty whack with ye old ball peen.
Old Aug 30, 2003 | 11:50 AM
CRneXt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda89 &raquo;</TD></TR><TR><TD CLASS="quote">
All is well after givinng the starter a heafty whack with ye old ball peen. </TD></TR></TABLE>
Don't count on the thing being fixed... Your solenoid is probably bad, but I have also see the windings go out, and a whack with the hammer temporarily resolved this as well. PLEASE GET IT REPLACED. It isn't a gone problem, until.
JM2CW,
Scott AKA CRneXt
Old Aug 30, 2003 | 06:35 PM
honda89's Avatar
Default Re: Car doesnt start?help needed (CRneXt)
yeah i know i just ment i got it to start. I just ordered a new starter from my local Napa store.
Old Aug 31, 2003 | 10:03 AM
Proper's Avatar
Check all the connections to your starter solenoid. I had a propblem like this and it ended up being a loose connection at the starter.
Old Aug 31, 2003 | 02:31 PM
honda89's Avatar
Default Re: Car doesnt start?help needed (CamoHatch)
Good call after i read i checked and the little wire was loose.
NiKKa NiKKy
Jun 30, 2022 09:59 PM
bigislandc2
Jun 2, 2008 02:48 PM
joe.wong321
Nov 24, 2007 11:41 PM
flatblk
Jun 9, 2005 09:41 PM
iblingidawg
May 5, 2005 02:48 PM
