Engine nosie with VAFC
Old Aug 29, 2003 | 07:44 PM
nikolai.'s Avatar
Default Engine nosie with VAFC
Ever since I installed my VAFC about a month ago I have been getting ridiculous amounts of engine noise looped into my speakers. I am pretty sure that this is the result of using a dual ground system. As an EE grad I think that this was about the stupidest thing I have ever heard of as this is basically creating a "ground loop" which is the #1 cause of engine noise.
Has anyone else experienced this, and if so were you able to resolve it? I could always just ground both grounds to the chassis, but that would result in incorrect voltages to and from the ECU (read: your VAFC could tell the ECU you are at 50% throttle but the ECU sees this as 45% throttle, etc).
Right now I have both grounds connected to the ground coming from the ECU about 6 inches apart (6 inches of 20 guage isnt enough to make a noticable ground loop) and I've STILL got the noise...
Old Aug 30, 2003 | 10:22 AM
skera's Avatar
Default Re: Engine nosie with VAFC (NB)
I have heard of this before. Some ignition control systems like msd cause the same type of noise. Msd sells a unit to stop this electrical discharge.
_Endless_
Mar 8, 2009 04:04 PM
NZludedude
Feb 22, 2005 02:09 AM
94Accord2c
Audio / Security / Video
Nov 21, 2003 07:03 AM
SwiftTypeR
Jan 5, 2002 09:40 AM
