weight reduction for a crx?
If it is full race strip all the bottom undercoat......then repaint with epoxy primier. Especially worth the time in the front half of the car.
If it's a street car and want quick lighter fell...if you haven't already, weight one of your front wheelswith tire and compare to $$$$light 14-15" with $$$ light weight tire, or Half DOT tire like on the STI Subarues (sp) I don't own on
hope it helps
AJ
hope it helps
AJ
street car
1. get rid of every unnecesary bolts and brackets. use zip ties accordingly.
2. remove rear wiper.
3. get a fuel cell
4. light weight exhaust system
5. remove all stereo components, heater core , vents
6. get rid of the factory seatbelt mechanism. not for street
7. fiberglass doors and lexan. not suggested for street
3. get a fuel cell
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dankbudz11357 »</TD></TR><TR><TD CLASS="quote">strip sound deadening from interior.</TD></TR></TABLE>
what's the easy way to do this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KoRE »</TD></TR><TR><TD CLASS="quote">dry ice is cleaner but can get expensive....
i tried using a torch got real messy</TD></TR></TABLE>
20 bucks of dry ice from baskin robins will clear a whole crx interior of deadening, it isn't messy and it is quicker than a heat gun.
Do it on a cold winter day and the job will go 10x easier also
I found out this weekend that the bumper supports form The 90 Si and the 88-89 Dx are a little differents... The older DX bumper is a good 15 lbs lighter... My Si finally got rid of some of the junk in the trunk... Literally...
Is that also true with the '91 CRX Si reinforcement bumper to be that much lighter?
you have the weight on the old DX model? How much older? I'll check mine if needed, I've been painting the under side and wheel wells for upcoming event
Dry ice? very nice I've been building up my forarms for nothing
AJ
2095 lb. '91 Si CRX and working
AJ
i been thinking of getting rid of the bumper supports, but i wonder what will keep the bumper in place/shape once i do that? last time i took my rex to the scales, it weight in at 2040 with the B swap. After taking off the spare, carpet, passenger side seat, heater core/blower, the rear speakers, and the front and rear bumper supports, i hope the car gets down to at least 1900 LBS!
have to keep heater core, and want to keep as much weight in the rear in the can as I can, just weighd what I took off, 208something.....oh ya with full cage and race seat, oh and driver, at 182lbs.
AJ
AJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokey2.0 »</TD></TR><TR><TD CLASS="quote">i been thinking of getting rid of the bumper supports, but i wonder what will keep the bumper in place/shape once i do that?</TD></TR></TABLE>
Zip ties, thats really the only way but it does work well, the bumper is pretty hollow and light.
fiberglass hatch. CF hood. fiberglass doors. lexan everywhere. light weight wheels. all sound **** gone. everything but the guage cluster gone... aka the whole dash and everything behind it.bye bye stock seat belts one 4 point to replace it.
ive only gutted lightly and im at 1980 lbs right now and im in a hatch. have fun.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BAZ »</TD></TR><TR><TD CLASS="quote">I dunno how safe I'd feel taking out the bumper supports.</TD></TR></TABLE>
They protect you to like 5 mph tops, thats it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Saturn »</TD></TR><TR><TD CLASS="quote">
They protect you to like 5 mph tops, thats it</TD></TR></TABLE>
that's the only reason why i'm willing to take them off!
Why are they there in the first place?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Saturn »</TD></TR><TR><TD CLASS="quote">
i left my front bumper support in for safety of my b series and the back i took off used all orig screws and made a bracket for the top of the bumper that just bolted in and kept it in alingment with the taillights, also on our drag crx cut the rear lip off the si bumper, to reduce drag.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BAZ »</TD></TR><TR><TD CLASS="quote">Why are they there in the first place?</TD></TR></TABLE>
To protect you up to 5 mph
