Zex and Type R cams in gsr.
Old Aug 16, 2001 | 04:47 PM
pstreck's Avatar
New User
Default Zex and Type R cams in gsr.
I'm getting the zex n20 system, would it be beneficial to also put in the type r cams?
Old Aug 16, 2001 | 05:23 PM
dubster99's Avatar
Default Re: Zex and Type R cams in gsr. (pstreck)
Your car will scream with that setup. I know someone that has a ITR intake cam and 100 shot of nitrous in the 12's.
Old Aug 16, 2001 | 05:34 PM
pstreck's Avatar
New User
Default Re: Zex and Type R cams in gsr. (dubster99)
what about the type r ecu?
Old Aug 16, 2001 | 07:38 PM
TypeC's Avatar
They work well together. You can see my car at AbsoluteVtecTuning . I've got CTR cams and a 55 shot (I like to keep it low). I ran 14.32@98.5 on streets (2.35 60') in 100 degree weather. I think You'll like it. -C
Old Aug 16, 2001 | 08:14 PM
valentinecr's Avatar
New User
you don't need a ecu, just get a Apexi Vtec contoller, that is only if you are trying to change your VTEC x-over point, even if you are trying to add more fuel. I would say get the VTEC controller if you want to change your VTEC x-changeover point or fuel adding or subtracting. If your trying to change your Redline then you'll need a new ECU. Otherwise it's not worth the money.
Cya
xfrankx
31
Oct 16, 2005 12:40 PM
IGotVTECyo
Jun 24, 2005 03:44 AM
JDMTypeS
Nov 27, 2002 07:18 PM
96tegsr
Oct 30, 2001 07:17 AM
