Really Quick: Code 18 or 8 ?!?
Old Aug 29, 2003 | 04:04 PM
AMG's Avatar
AMG
Default Really Quick: Code 18 or 8 ?!?
I know I am a dumbass and forgot, but when I chek the engine code and it blinks one slow and then eight times fast, is that 18.....
Thanks
Old Aug 29, 2003 | 07:54 PM
TeStUdO's Avatar
Default Re: Really Quick: Code 18 or 8 ?!? (dohcVTEChatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcVTEChatch &raquo;</TD></TR><TR><TD CLASS="quote">I know I am a dumbass and forgot, but when I chek the engine code and it blinks one slow and then eight times fast, is that 18.....
Thanks</TD></TR></TABLE>
yes
Old Aug 29, 2003 | 08:14 PM
AMG's Avatar
AMG
What is a code 18??
I referred back to this post, but there is no 18!?!?
https://honda-tech.com/zerothread?id=605594
Old Aug 29, 2003 | 08:21 PM
TeStUdO's Avatar
did you reset the ecu????? did you try getting the code again? i couldnt find code 18 either, i thought it was just the booze though
Old Aug 29, 2003 | 08:27 PM
AMG's Avatar
AMG
Default Re: Really Quick: Code 18 or 8 ?!? (TeStUdO)
no, I havent, I will go out and try now, but did you reset it when you threw that code??
Old Aug 29, 2003 | 08:28 PM
TeStUdO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcVTEChatch &raquo;</TD></TR><TR><TD CLASS="quote">no, I havent, I will go out and try now, but did you reset it when you threw that code??</TD></TR></TABLE>
i never threw the code, i dont throw codes my car doesnt run
Old Aug 29, 2003 | 08:50 PM
AMG's Avatar
AMG
....ok well I just reset the ecu and now its not throwing a code at all!?!?
Thats weird for a ecu to throw a code not even labeled in the engine code book?
Old Aug 29, 2003 | 09:59 PM
TeStUdO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcVTEChatch &raquo;</TD></TR><TR><TD CLASS="quote">....ok well I just reset the ecu and now its not throwing a code at all!?!?
Thats weird for a ecu to throw a code not even labeled in the engine code book? </TD></TR></TABLE>
well if its not throwing a code you have nothing to worry about. you probably just cant count and it was a different code
Old Aug 31, 2003 | 07:07 AM
AMG's Avatar
AMG
well check engine light came on again?!! I think it was because I reset the ecu and didnt give it enough time to warm up and read the codes again......Anyways its still throwing code 18?!?!
Can anyone tell me what the hell the code is?
Old Aug 31, 2003 | 07:14 AM
Chiovnidca's Avatar
How long is it between the long and short blinks? Could it be two seperate codes?
Old Aug 31, 2003 | 09:25 AM
Hondaaccordvtec's Avatar
Default Re: Really Quick: Code 18 or 8 ?!? (Chiovnidca)
I was just going to say that - Code 10 and Code 8 maybe?
Code 8 - Crankshaft sensor
Code 10 - Intake Air temp. sensor
Old Aug 31, 2003 | 11:05 AM
Chiovnidca's Avatar
Default Re: Really Quick: Code 18 or 8 ?!? (Hondaaccordvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondaaccordvtec &raquo;</TD></TR><TR><TD CLASS="quote">I was just going to say that - Code 10 and Code 8 maybe?
I thought code 8 was for the TDC sensor.
Old Aug 31, 2003 | 11:39 AM
TeStUdO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">
I thought code 8 was for the TDC sensor.</TD></TR></TABLE>
it is
Old Sep 1, 2003 | 04:43 PM
AMG's Avatar
AMG
What the hell.....isnt that dealing with pistons (top dead center)
It didnt start throwing the code till I replace dist. and got it timed?! So what should I do then if I am throwing this code and is it damaging anything?!......Sorry I am just drawing a blank?
Thanks for the reply's
Dylan
Old Sep 1, 2003 | 04:54 PM
TeStUdO's Avatar
your timing might be off, check that and go from there
Old Sep 1, 2003 | 08:59 PM
chictunner97ex's Avatar
Default Re: (TeStUdO)
exactly what TeStUdO said your timing might be off, check it correct it and make sure you are clearing your ecu memory correctly by removing the fuse for over ten seconds or unplug your battery for over a half hour then it should clear. if it keeps coming up then you have a problem. also make sure you are reading the blinks right. i don't want you to get offended when i say that but trust me it gets confusing real easily. good luck gloria
Old Sep 2, 2003 | 07:03 AM
AMG's Avatar
AMG
Default Re: (chictunner97ex)
no, the timing cant be off, I had a local shop do it with a timing gun. But incase they did it wrong, would this be the direct cause? Also, it is the right code for sure...lol........Thanks though
VAAJ
36
May 7, 2009 07:35 PM
slomofo
Jul 15, 2008 09:49 AM
djcue_530
Mar 15, 2007 08:53 AM
NathanielH
May 25, 2006 11:29 PM
